will regular ground control work with my konis...
will regular ground control work with my konis yellows or do you need ground control springs for koni yellows ??
eh... what I mean is that, are all ground control the same ? or do I need ground control that are mad for koni yellows ?
No, they're not interchangeable. I doubt it but it might be possible to change out the piece on the sleeve that sits on the shock body, and make it fit.
is there a difference in reliability between the ground control with koni adapters and the ground co
racekar
Jun 1, 2004 02:11 PM
