just did my timing belt now its not revving past 2000
Old Aug 17, 2004 | 07:19 AM
fartman's Avatar
Default just did my timing belt now its not revving past 2000
i did my timing belt this weekend, not to bad of a job besides breaking the crank bolt free, but other then that just turning wrenches. anyways on the first start up the car cranked like normal, idled for about 10 minutes and was on the boggy side but i thought it was bad gas, but after draining the tank and adding fresh gas now it wont rev any higher then 2000 and before the new gas it was revving fine into the 5000s. anyone have any ideas of what it could be??
Old Aug 17, 2004 | 07:20 AM
fartman's Avatar
Default Re: just did my timing belt now its not revving past 2000 (fartman)
oh forgot to say its a 90 2.2 f22 sohc.
Old Aug 17, 2004 | 07:30 AM
david90's Avatar
pretty sure your timing is off. Recheck it and make sure u look at the timing marks straight on and not at an angle.
v4lu3s's Avatar
RTFM
you sure you got timing set right? it may be that hte cam timing is pretty far off, specially if it seems really boggy.
Old Aug 17, 2004 | 12:47 PM
fartman's Avatar
i thought i lined everything up right, maybe not. will tear it all apart again and start over.... that damn crank bolt was horrible, hope its easier this time. thanks guys...anyone done this job before? also a quick question, IF i did a h22 swap into a 90 accord sedan, where can i find the kits with mounts and electrical harnesses?
Old Aug 17, 2004 | 02:52 PM
Chiovnidca's Avatar
Default Re: (fartman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fartman &raquo;</TD></TR><TR><TD CLASS="quote">i thought i lined everything up right, maybe not. will tear it all apart again and start over.... </TD></TR></TABLE>
Just pull off your valve cover and check the timing marks to start with.
Old Aug 17, 2004 | 05:49 PM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fartman &raquo;</TD></TR><TR><TD CLASS="quote">i thought i lined everything up right, maybe not. will tear it all apart again and start over.... that damn crank bolt was horrible, hope its easier this time. thanks guys...anyone done this job before? also a quick question, IF i did a h22 swap into a 90 accord sedan, where can i find the kits with mounts and electrical harnesses?</TD></TR></TABLE>
you already have the moutns and harnesses you need, the ones you use for the f22 work fine for the h22, just need to add a few wires for vtec.
Old Aug 19, 2004 | 10:21 AM
fartman's Avatar
just turned the pulleys to line up the marks and they were fine. how far off will make this difference, 2mm 1mm ?
Old Aug 19, 2004 | 10:23 AM
fartman's Avatar
pull off my valve cover? the timing marks werent under the valve cover, they were on the pulleys and on the side of the motor. am i missing marks?? is so where are they?
Old Aug 19, 2004 | 10:25 AM
Turbowa's Avatar
You may want to check and see if the crank possitioning sensor is on right.
Old Aug 19, 2004 | 11:03 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fartman &raquo;</TD></TR><TR><TD CLASS="quote">pull off my valve cover? the timing marks werent under the valve cover, they were on the pulleys and on the side of the motor. am i missing marks?? is so where are they?</TD></TR></TABLE>
Line the two marks on the cam pulley so they are even with the head surface. And the white mark on the flywheel should line up with the pointer at the same time.
Old Aug 19, 2004 | 01:26 PM
fartman's Avatar
white mark on the flywheel?? oh crap thats what i miseed....guess that means more bloddy knukles..
Old Aug 19, 2004 | 05:56 PM
b4croozin's Avatar
I'm changing timing belts, water pump, etc. on my son's 92 Accord. Best time saving investment was in the crank pulley tool. Needed it today and a local store was able to get it within 2 hours. I really lucked out after reading about it today! I am 4 hours into it and have to get the water pump out next. Can't work on it until Saturday so all advice will be appreciated.
Old Aug 20, 2004 | 12:20 PM
fartman's Avatar
bump
92gs...92dx
12
Aug 15, 2007 09:31 AM
Next GenRacing
Dec 13, 2005 05:52 PM
dreweg
Jul 14, 2003 10:33 AM
sivik2nr
May 29, 2003 09:30 PM
flyrod
Aug 14, 2002 06:38 PM
