messed up flywheel
Old Aug 17, 2004 | 06:41 AM
rice a roni's Avatar
Default messed up flywheel
yeah i gotta d16y8 replacement in my garage...the flywheel looks like this
you think it'll be safe to just run it or should i get the screws that look like they're cut off taken out and put new ones in?
new pics up...no weenies now
Modified by allmighty2door at 3:41 PM 8/18/2004
Old Aug 17, 2004 | 06:59 AM
WAFFLES's Avatar
Default Re: messed up flywheel (allmighty2door)
worst drawing evAr!
So you have bumps on your weenie? Cause that's what your drawing looks like.
Old Aug 17, 2004 | 07:38 AM
EM1 Loi's Avatar
extract the screws that are inside of the motor and get new ones.
Old Aug 17, 2004 | 07:44 AM
SnowSurfer's Avatar
Default Re: messed up flywheel (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">worst drawing evAr!
So you have bumps on your weenie? Cause that's what your drawing looks like.</TD></TR></TABLE>
rofl!
on topic though, get new screws, and some ointment for your weenie bumps
Old Aug 17, 2004 | 08:54 AM
Default Re: messed up flywheel (SnowSurfer)
oh sorry on the weenie drawing...excuse me on that picture...just didnt have the camera to take a picture so i did my best...hehe im the best artist evar
Old Aug 17, 2004 | 09:10 AM
MNEJ2GUY's Avatar
if you can't provide a decent drawing how are we to help you....
Modified by MNEJ2GUY at 1:44 PM 8/18/2004
Old Aug 17, 2004 | 09:40 AM
Ignitecivic's Avatar
Default Re: messed up flywheel (MNEJ2GUY)
look like a dick with a disease.
Old Aug 17, 2004 | 10:21 AM
nocturnaldragon's Avatar
U have to get new screws, with them cut like they are it wont stay seated on the engine right cause vibrations and youll go thro clutches like gasoline......
Old Aug 17, 2004 | 10:41 AM
spyderracing's Avatar
Default Re: messed up flywheel (nocternaldragon)
Rofl your prob is you have an STD!
Old Aug 17, 2004 | 10:54 AM
2point2's Avatar
HAHAHA..
Old Aug 17, 2004 | 09:52 PM
japspec's Avatar
HAAAAAAAAAAAAAAAHAAAAAAAAAAAAA. You are crazy man your picture looks like ***.
Old Aug 18, 2004 | 12:42 PM
Default Re: messed up flywheel (japspec)
turns out that aint the only thing wrong with the motor. had some screws that are jammed that wont let the engine crank more than half a crank. fucken checking if the piston rings are still good. well the screws that are broken off seem to hold the flywheel to the crank and it doesnt seem wiggle...think it'll matter?
Old Aug 18, 2004 | 12:44 PM
Deemeetree's Avatar
Electrician
Bwahahahahahahahahahaha! Nice one!
I bet you'll have to remove those cut bolts and replace them. Drivetrain components you DON'T want to mess with and do half-assed jobs.
ecahatch's Avatar
Senor Miembro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmighty2door &raquo;</TD></TR><TR><TD CLASS="quote">yeah i gotta d16y8 replacement in my garage...the flywheel looks like this
LMAO!!!!!!!!!!!!!!
Old Aug 18, 2004 | 01:08 PM
Kelly.'s Avatar
I've quit using this account
DO NOT DRIVE LIKE THAT.
you will need to get all 6 bolt on there the way they should be.
dont risk it...... pimple dick
Old Aug 18, 2004 | 01:18 PM
vtec69's Avatar
Nice drawing
Yeah defenitly extract those screws and replace them or your flywheel will fly off
Old Aug 18, 2004 | 01:22 PM
READ THE FRICKEN REPLYS!!!!
YES YOU NEED TO FIX THEM AND HAVE ALL 6 OF THEM IN THERE!!!!!!
If your not gonna bother to listen dont post your crappy *** pic with questions if your not going to listen to the answer. IF you dont fix that your just begging for more proplems like you would be begging to get *** raped by going to prisen wearing ***-less pants! ITS JUST NOT A GOOD IDEA!
FIX IT!!!!!!!!!!!!!!!!!!!!!!
Old Aug 19, 2004 | 09:15 AM
yeah i heard man...dont be tripp'n son. im working on it in my garage...thanks for the replys
Old Aug 19, 2004 | 09:20 AM
Member 00841's Avatar
Default Re: messed up flywheel (gs R inteqras)
do not run it LOLOLOLOLOLOLOLOLOLOLOLOLOL
reverse drill it
Old Aug 19, 2004 | 09:23 AM
Default Re: messed up flywheel (JESUSDREAD)
ROFL "pimple dick" hahahahahahahahaha
Old Aug 19, 2004 | 09:36 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: messed up flywheel (spyderracing32)
This thread is funny.
About those bolts, your probably going to need to take that to a machine shop because those bolts are torqued down real tight and probably broke when someone tried to remove them which means they're even harder to remove now for some reason. You're not going to want to try and Easy-Out those cause I'm 99% sure you'll just snap the Easy-Out. If you try drilling them yourself and don't hit the center exactly, you can mess up the threads. I would just take it to a machine shop and have them remove the broken bolts and make sure the threads are still good. Before you take it in though, remove the remaining bolts so they don't need to worry about the flywheel and so you know they can be removed. You don't want to take it to the shop and have the work done to just come home and try removing the other bolts and break another one.
Old Aug 19, 2004 | 10:07 AM
jspresso's Avatar
Default Re: messed up flywheel (TouringAccord)
looks like someone failed kindergarten-6 grade
Old Aug 19, 2004 | 10:16 AM
jolt-tsp's Avatar
Default Re: messed up flywheel (jspresso)
definitely drill them out, and replace them
I think a new title might be in order for allmighty2door
Old Aug 20, 2004 | 07:14 AM
Default Re: messed up flywheel (jolt-tsp)
i got 2 of the 3 out...took a cutter and cut a slit in the middle then used a flat head to screw them out...the third one is kind of stuck so i'll try again later. oh yeah anybody know if a z6 power steering will fit on the y8 block?
Anthonyl469
26
Jul 22, 2004 10:29 AM
Drag-On
May 4, 2004 05:36 AM
kotetu
Jun 26, 2003 08:51 PM
yellowbuffalo
Jun 20, 2003 04:45 PM
NC-B17A
May 9, 2002 08:40 PM
