Honda S2000 Honda S2000
S2000 Owner Questions
Old Aug 16, 2004 | 11:41 PM
CWESTINAP1's Avatar
Default S2000 Owner Questions
hey s2k guys i have a few questions.
1. Where are the jack/lift points on the front and rear of the car?
2. Is there anyway to go from a plastic rear window to a glass rear w/out replacing the whole hardtop?
3. Is it possible to use '04 s2000 headlights on pre 04 s2000's?
4. Where is the maintanence button?
sorry for the dumb ?s but don't have a manual
Old Aug 17, 2004 | 02:25 PM
CWESTINAP1's Avatar
Default Re: S2000 Owner Questions (CWESTINDC2)
bump for some answers
Old Aug 17, 2004 | 02:37 PM
VTECorona's Avatar
On the sides under the door area towards the tire on each end. You will see the reinforcements when you look.
No, you need to replace the whole softtop.
4. Where is the maintenance button?
I assume you are asking how to reset the "maintenance required" light.
You press and hold the TRIP button, turn the key until MAIN REQD lights up and release the TRIP button when the light goes out.
Old Aug 17, 2004 | 03:13 PM
s2k_al's Avatar
If your gona replace the soft top for a glass rear window, you might as well just get a hard top because IMO it looks better and the soft top will be expensive too. good luck
Old Aug 17, 2004 | 08:31 PM
CWESTINAP1's Avatar
Default Re: S2000 Owner Questions (VTECorona)
okay, thanks for the help. already changed my oil, and added water to my radiator.
Old Aug 17, 2004 | 10:28 PM
Razor's Avatar
you can use the differential as a jack point to, if you want.
Old Aug 18, 2004 | 01:26 AM
CWESTINAP1's Avatar
Default Re: S2000 Owner Questions (Razor)
what about my ? #3?
Old Aug 18, 2004 | 05:53 AM
jolt-tsp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">you can use the differential as a jack point to, if you want.</TD></TR></TABLE>
You should use a 2x4 between the jack and diff though (or I always do anyway)
Old Aug 18, 2004 | 06:54 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 &raquo;</TD></TR><TR><TD CLASS="quote">what about my ? #3?</TD></TR></TABLE>
I've not taken precise measurements or anything, but after having parked my 04 next to an 03, the headlights appear to be the same shape. The only aesthetic differences were the change from an all orange side, to the separated parking bulb and turn bulb. Also, a few little silver garnishes inside the headlamp assembly. Other than that, it appears as though they are the same dimensions.
Old Aug 18, 2004 | 08:34 AM
CWESTINAP1's Avatar
Default Re: S2000 Owner Questions (ScreaminTeg)
cool, can anyone confirm this?
Old Aug 18, 2004 | 09:00 AM
jolt-tsp's Avatar
I read a thread a while back, and I want to say you need to swap the bumper and fenders as well. Wait for better feedback than mine though.
Old Aug 18, 2004 | 09:51 AM
VTECorona's Avatar
Default Re: S2000 Owner Questions (jolt-tsp)
Search s2ki.com if you really want to read alot about s2k's. That forum moves a little quicker than the s2000 forum on honda-tech plus it has years of archived threads. Like any forum, search before posting a new thread or they will probably bust your *****.
Old Aug 18, 2004 | 10:27 AM
Jdm_Rice_Monstr's Avatar
none
Old Aug 18, 2004 | 02:48 PM
PNB's Avatar
PNB
GatorNATION
Default Re: S2000 Owner Questions (Jdm_Rice_Monstr)
'04 headlights WILL fit, but with minor modification.
I don't know the exact modifications necessary, but I do know its not just plug and play. Search on S2ki.com for a DIY.
Old Aug 19, 2004 | 11:18 PM
CWESTINAP1's Avatar
hey guys i tried holding the trip button down but all that happened was the trip got reset. am I suppose to do this when the car is on or off? is this the correct procedure?
Old Aug 20, 2004 | 12:35 AM
CWESTINAP1's Avatar
nm got it. held down both trip and mph/kph when car was off turned key all the way and it turned off.
Scott.
Jan 21, 2012 10:25 PM
bb6
Aug 25, 2005 02:22 PM
boostedhb
Honda S2000
Mar 28, 2005 10:07 PM
