Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 Accord Headlight Alignment
Old Aug 16, 2004 | 09:35 PM
GraphiteV6's Avatar
Default 2003 Accord Headlight Alignment
I've posted this question in the past but still have not found an answer. I wanted to know how I can go about aligning my headlights on a 2003 Accord Sedan. There aren't any direct screws that I see from the engine bay or underneath the car. If anyone can point me in the right direction or have a picture of the specific *****, please respond.
Old Aug 16, 2004 | 09:49 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: 2003 Accord Headlight Alignment (GraphiteV6)
Why do you have to align head lights on 2003 accord?
if it has a warrenty i would let honda take care of this if there even is such a thing
Old Aug 17, 2004 | 02:52 PM
GraphiteV6's Avatar
Default Re: 2003 Accord Headlight Alignment (91EXRMANUAL)
The reason that I wanted to align my headlights was that after I installed Super White Bulbs (from SPP), they seem to point up too high. I see this line on the garage and it seems higher than it was with OEM bulbs. I've been high beamed by cars going in the opposite direction (i don't know if it's because these are bright and they think i'm driving on high beams or they are actually pointed up too high). Also, I don't even see a line on the ground in front of the car, almost like the lights are parallel to the ground. Any suggestions?
Old Aug 18, 2004 | 05:45 AM
JimBlake's Avatar
Open the hood, look at the black plastic shroud behind the headlights. There's a hole on each side, with a symbol like a curved double-ended arrow & "UP" & "DOWN". D'ya think maybe there's an adjustment screw down in that hole?
Old Aug 19, 2004 | 12:13 PM
adamsauce's Avatar
Default Re: 2003 Accord Headlight Alignment (JimBlake)
ive looked all over and i even had the assembly in my hand, never saw a screw
Old Aug 19, 2004 | 01:18 PM
Camelflaj's Avatar
Default Re: 2003 Accord Headlight Alignment (adamsauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsauce &raquo;</TD></TR><TR><TD CLASS="quote">ive looked all over and i even had the assembly in my hand, never saw a screw</TD></TR></TABLE>
The screw is hidden, so you need to get a long Screwdriver to adjust the headlights.
http://www.v6performance.net had a thread about this.
Old Aug 19, 2004 | 08:59 PM
GraphiteV6's Avatar
Default Re: 2003 Accord Headlight Alignment (Camelflaj)
anyone care to take a picture or already have one? i've looked and did not find anything...
Old Aug 20, 2004 | 03:46 AM
JimBlake's Avatar
Near each end of the hood prop-rod when it's down & clipped into place. Take a flashlight & look into that hole. At the right angle you'll see a couple teeth on the edge of a gear. You'll use a phillips screwdriver like a pinion to mesh with that gear. It looks like you can put the screwdriver in the wrong angle & it won't engage that gear.
Old Aug 21, 2004 | 11:15 AM
GraphiteV6's Avatar
I see it now. It even says Up/Down on both sides towards the inside of the car. I'm gonna fiddle around with the adjustments once it gets nice out cause the screw driver didn't seem to do much. thanks for all your help! If anyone wants a pic of the exact locations, i'll post it up for you.
Old Dec 1, 2020 | 09:33 AM
Jeff McNamara's Avatar
Incorrect. Here is a proper video on where the actual adjustment screw is.
jeff_finger
Jan 1, 2015 06:04 PM
ramman05
Sep 30, 2008 12:56 PM
Alpine6
Dec 16, 2002 05:20 PM
