ZC in 88 hatch
Old Aug 16, 2004 | 07:55 PM
dragEF8's Avatar
Default ZC in 88 hatch
I bought a ZC teg for $300, I am putting the motor in a 88 hatch. What else will i need? I need info asap, as I am wanting to finish it tomorrow. Any help would be great...
Old Aug 16, 2004 | 08:39 PM
EFin' Kyle's Avatar
Default Re: ZC in 88 hatch (dragEF8)
dont get crx axels get integra axels. i had a dohc zc im my 90 crx and i kept breaking the axels. get aftermarket ones. i dont think u need different mounts im not sure on that tho. good luck with the ZC
Old Aug 16, 2004 | 08:45 PM
blah13's Avatar
Default Re: ZC in 88 hatch (crxstreetracer90)
If you got this ZC from a teg it wont bolt right in, the mounts are different. I "believe" its just the driver side mount that needs to be swapped with an a6 one, not 100% sure if thats the only one though. And as long as you use your stock tranny that came with the car you can re-use your axles, you dont need aftermarket ones.
Old Aug 16, 2004 | 08:47 PM
EFin' Kyle's Avatar
Default Re: ZC in 88 hatch (blah13)
i dont think he can use the crx ones bcuz he will be making alot more power than a stock crx would.
Old Aug 16, 2004 | 09:08 PM
blah13's Avatar
I've run my ZC at the track with my stock axles 20 or so times, plus daily driving, 206k miles on them with no problems, you either have bad luck or have rough launches. You wouldnt happen to use autozone axles? Theyre hit and miss on quality. I'd say 90% of people who do ZC swaps use stock axles, even turbo or sprayed guys use em, course thats getting on the edge but many have no problems.
Old Aug 16, 2004 | 09:48 PM
dragEF8's Avatar
everything is coming from the 'Teg even the axles if they are direct swap, I figured might as well...let me know. Thanks btw for the quick replies...
Old Aug 17, 2004 | 11:28 AM
dragEF8's Avatar
bump.
Old Aug 17, 2004 | 12:29 PM
integ u's Avatar
I see not point in buying a D16A1 with diffent mounts then a civic, 115hp and god knowns how much torque and then putting it in a civc. Good luck on finding a ZC crankshaft, cams and pistions by them self's, if you want more power that is.
Save your $300 and save up for a 88-89 ZC with civic mounts 130hp and 109lbs tq
If your going DOHC and staying D-series do it right and just get a ZC.
Old Aug 17, 2004 | 01:02 PM
ServiceAdvisor's Avatar
Why use the Integra tranny? It has longer gears which means higher ETs. Get an 88-91 Si tranny and bolt that biatch in there. Shaves up to .5 off ETs on some ppl. Unless you plan on highway racing :/. As for the stock axel thing, I have used my stock axels on my DOHCZC for a year or so and I have had no problem, and I have blown a differential apart. - Darrell
Old Aug 19, 2004 | 10:00 AM
dragEF8's Avatar
Default Re: (DOHCZCCRXSi)
I am using the DX tranny, cause the trans mounts are the only ones that dont line up. If u use the DX tranny = problem solved. I was wondering if anyone has done this, cause I need some help to get it running by next week....let me know.
BTW: the hatch is a DX
Old Aug 19, 2004 | 10:01 AM
ek_99_SiR's Avatar
Default Re: (dragEF8)
ok u bought the wrong ZC but this can be fixed! buy a black top ZC head and bolt it to the integra block and youll be ok
Old Aug 20, 2004 | 06:19 PM
spec_sef's Avatar
just say no to the auto zone axles, i had had them take a sh#$ two times. the only good thing about them was you can return them. have funnn with your ZC
i did....
SRZsmack
Jun 4, 2009 02:21 AM
h22_crx
Aug 30, 2005 05:59 AM
spyz34
Mar 31, 2004 04:49 PM
batman21
14
Mar 28, 2004 01:12 PM
crxracing77
Nov 18, 2002 10:43 AM
