***HELP! right axle coming out of transmission :eep:***
Old Aug 16, 2004 | 07:33 PM
DIYaccord's Avatar
Default ***HELP! right axle coming out of transmission :eep:***
Here's a story:
my cv-joint boot busted a couple weeks ago, so I replaced the whole axle...I noticed yesturday some tranny fluid on the ground and on my way to work a weird thumping noise when I drove and turned left. I got out, jacked it up and inspected and found this...
Here's a picture:
My Guess and Solution:
Its the set ring...replace and it should be ok...(hope!)
Old Aug 16, 2004 | 08:40 PM
DIYaccord's Avatar
Default Re: ***HELP! right axle coming out of transmission :eep:*** (DIYaccord)
Anyone
Old Aug 16, 2004 | 09:16 PM
91EXRMANUAL
Guest
Posts: n/a
Just smack it back in with a rubber mallet or hit the end of the shaft with a hammer.. (dont smash it too hard)
make shure that little ring arount the connection to the tranny kinda locks into place , i had to do it on my accord i just kept pulling on it and hitting it in untill it locked a little bit and you could not pull it out easly..
if it doesent click in then check the ring on the end
if that all doesnt work , exchange the half-shaft with another one.
Old Aug 16, 2004 | 09:31 PM
DIYaccord's Avatar
Default Re: ***HELP! right axle coming out of transmission :eep:*** (91EXRMANUAL)
Do I risk damaging anything by pulling on it?
Old Aug 17, 2004 | 12:14 AM
david90's Avatar
Was it in before and came out ? if so, u might need to check the snap ring @ the end of the axle cuz it's what keeping the axle lock into the tranny.
Old Aug 17, 2004 | 03:42 AM
motormanSR's Avatar
there is not much risk in pullung on it.....isn't that how you got it out in the 1st place
Old Aug 17, 2004 | 08:45 AM
DIYaccord's Avatar
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">Was it in before and came out ? if so, u might need to check the snap ring @ the end of the axle cuz it's what keeping the axle lock into the tranny.</TD></TR></TABLE>
Yes it was, and that's what I was thinking of doing...
Bought some new OEM honda snap rings so i'm just gonna replace it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormanSR &raquo;</TD></TR><TR><TD CLASS="quote">there is not much risk in pullung on it.....isn't that how you got it out in the 1st place</TD></TR></TABLE>
Thats the thing, I was told any kinda pulling would ruin the axle...so I did what helms said and used a crowbar as a lever to pry it out safely.
Modified by DIYaccord at 10:14 AM 8/17/2004
Old Aug 17, 2004 | 09:57 AM
Eddiebx's Avatar
Default Re: ***HELP! right axle coming out of transmission :eep:*** (motormanSR)
pull on it too hard and your inner joint will seperate and all the bearings will fall out. then your gonna have to take the boot apart and line up all the bearings again and put it back together
if its coming out and you seated it properly teh first time, then the snap ring is probably missing. If the snap ring on the end of the axle is there, then you probably never seated her in correctly, which means you need to give it a harder smack to seat it.
Old Aug 17, 2004 | 12:25 PM
david90's Avatar
Pull only on the outer race and not on the boot and any point after that.
Old May 22, 2006 | 02:30 PM
PINKS's Avatar
I want a CRX tattoed on my butt
I think I have this problem as well, just gonna try and smack the end of the wheel with a rubber mallet
Or do I have to take everything apart first and then give it a good smack?
If I do have to take it apart, do I have to hit it form the very end of the axle, or just the hard black piece about 3" closest to the tranny
prelude2.2vtec
Mar 19, 2012 08:01 AM
darot
Jul 18, 2009 01:13 PM
h2beg
Jul 21, 2008 06:03 PM
D'PEXi
Jul 7, 2007 12:16 PM
DIYaccord
Aug 17, 2004 09:15 AM
