Replacing Blower Motor... need help.
Old Aug 16, 2004 | 06:47 PM
VolunteersRock!'s Avatar
Default Replacing Blower Motor... need help.
Hey, I'm replacing my blower motor in my 1990 Accord, but it's so complicated to get it out of the dash. Any hints?
Old Aug 21, 2004 | 08:54 PM
PnX-R's Avatar
Default Re: Replacing Blower Motor... need help. (VolunteersRock!)
Is that the same model as the 93 Accord??.. If so, what you have to do is remove the two plastic covers on the side of the dash and remove the two bolts there.. Then pull the dash out a little bit for more clearance. And if you have A/C, you'll need to pull out the ECU. Just unplug the bottom two connectors and move it to the side..
It's not as complicated as everyone says it is.. Just the airbox out is hard. But remember how you got it out because that's the only way it's going to go back in..
And as for removing the motor from the fan, move the plastic lock/clip and drive the fan off with a punch..
Have fun, flat rate is suppose to be 2.4hrs..
Old Aug 22, 2004 | 01:40 AM
Monkey Fing a Coconut's Avatar
Default Re: Replacing Blower Motor... need help. (PnX-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnX-R &raquo;</TD></TR><TR><TD CLASS="quote">And if you have A/C, you'll need to pull out the ECU. Just unplug the bottom two connectors and move it to the side..
y would he have to remove the ecu??? when i replaced mine in my 93 accord i just slid the dash out a bit and wiggled it out
and make sure u remember how everything goes back together....
jshep
Sep 29, 2014 04:00 PM
jrw2scw
Jul 29, 2005 06:20 AM
Foxcow
13
Jul 18, 2005 10:27 PM
jBj
Mar 23, 2005 10:25 PM
essex
Acura TL, RL & ZDX
Dec 19, 2004 02:15 PM
