Header compatibility... Easy question, need quick help
Old Aug 16, 2004 | 04:36 PM
Nate047's Avatar
Default Easy question, need quick help... B16A header...
A header for a 94-01 GSR will bolt right up to a 99-00 Si, right? Is the only difference the ground clearance?
A good deal came up, and I need some info ASAP. Thanks for the help.
Nate
Modified by Nate047 at 4:56 PM 8/17/2004
Modified by Nate047 at 4:57 PM 8/17/2004
Old Aug 17, 2004 | 03:56 PM
Nate047's Avatar
Default Re: Header compatibility... Easy question, need quick help (Nate047)
ttt, fukin A guys, this is an easy question
Old Aug 17, 2004 | 03:59 PM
sinister00's Avatar
Default Re: Easy question, need quick help... B16A header... (Nate047)
The header should bolt up, if anything the length may be different.
Old Aug 17, 2004 | 04:06 PM
HATCHingMN's Avatar
gsr header will hang lower to the ground then B16 header.....also you will need to custom a flange for the header to meet the Cat because the bolt pattern is different on the cat/b-pipe!!
Not a bolt on affair!!!
Old Aug 17, 2004 | 04:15 PM
Nate047's Avatar
Default Re: Easy question, need quick help... B16A header... (HATCHingMN)
Can an exhaust shop do this flange **** for me? Unfortunately I have no garage/powetools, so I have to have it installed somwhere anyway...
Old Aug 17, 2004 | 04:17 PM
HATCHingMN's Avatar
yes any exhaust/muffler shop can do it!!
Old Aug 17, 2004 | 04:39 PM
Nate047's Avatar
Thanks!
80 dolla crx hf
Oct 3, 2008 04:28 PM
Honda Crx
Feb 21, 2006 11:21 AM
blowbyu24
Nov 14, 2005 01:55 PM
IntegraType-R
Sep 30, 2005 06:06 PM
TurboTeG4
Jan 3, 2005 12:56 PM
