Reseting SRS system?
I am trying to reset my SRS system by using a certain method mention by some H-T members where you disconnect MES plug from top of fuse box. I wanna know how in the hell i am supposed to pull that stupid yellow plug out. Ive never had a problem disconnecting any connection on a Honda until i tried this. I push down the little clip on the top and pull but no luck getting it out. If anyone has any tips would you please let me know. Thanks
Re: Reseting SRS system? (Si_Allen)
there's a clip on top that you can't see...it's part of the housing the plug plugs in to...it should pop up, then you'll be able to reset your srs.......good luck.....
Re: Reseting SRS system? (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=264288
Search is your friend! </TD></TR></TABLE>
If you read clearly You will see that I asked how to unplug the connection. I already searched and printed out all the steps neccesary to reset. Thanks bud.
those aren't a direct pull....i want to say that you squeeze down on a part and slide it out. dangit I wish I had it in front of me. Just stare at it for awhile and you'll figure it out.
Re: (atc5)
It has a little button on top which you can push down on, like most of the electrical connections on a Honda. I push in as far as I can and pull like there is no tomorrow and still it wont budge. If anyone has any insight let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si_Allen »</TD></TR><TR><TD CLASS="quote">
If you read clearly You will see that I asked how to unplug the connection. .</TD></TR></TABLE>
My bad, I read the title and the second post... on me!
Weird that it doesn't want to come out. I had all mine apart in the integra really quick when I tore the dash out. Its not easy. Some of the SRS stuff has tricky connectors on it.
I just hope they don't charge me to much to fix this **** at the dealership. A friend of a friend replaced the rack and pinion and ever since then the SRS light has been on and my cruise control no longer works. I checked over all connections and can't notice anything out of place.
Dokta
08-16-2016 06:57 AM
darkmentality
02-06-2013 05:10 PM
shauniewalnuts
13
10-24-2003 07:14 AM
