stock civic height
im doing the bolt and washer camber kit for the back, (97,ex) what is the hight from the ground to the bumper , or however they measure it. I need to see how many inches my car is lowered. my book dosnt say..
thanks...i just did the bolt and washer rear camber adjustment....is there any reason that i had to ad a washer more to one side than i did the other ( i used 3 on left, but 4 on th right)
my back coil's are the same....if i had one higher than the other on the front...would that cause it to do this in the back? i thought i got the front as close together as i could.
Negative camber isn't always equal. When I got my alignment done, the rear right was like -3 and the rear left was -2.5. As long as there isn't any damage then you're fine.
accordj30guy
Suspension & Brakes
Jul 14, 2006 03:43 PM
jdmaccord23
Jan 27, 2005 07:58 PM
94AccordSedanEX
Oct 16, 2003 08:54 PM
