Need help...fast
Okay here is the situation. Went to put in my pistons today, and behold, the main bearings are shot, and a nice little slash not big on the crank. Here is my questions, should I have it fixed (polished out) or just use new crank? My other question is, will i be fine using GSR rod bearings on a GSR crank, with ITR Rods.??? All input is really needed and appreciated.
you'll be fine if you get the right sized rod bearings...use plastigauge to check the clearances
don't know bout the crank though. a new crank is not cheap
[Modified by da6vtec, 11:47 AM 12/2/2001]
[Modified by da6vtec, 11:48 AM 12/2/2001]
