TypeRPauls ITR finally hits the Dyno!! Graph inside
Old Aug 16, 2004 | 09:10 AM
TypeRPaul's Avatar
Default TypeRPauls ITR finally hits the Dyno!! Graph inside
Well i finally go everything done for my mild street set up and got it tuned by Lawrence of DSR (http://www.dynospotracing.com/) in San jose. Big to Austin for recomending him . Now onto my set up:
JDM 4-1 Header (thanks Marcus at Heel-toe)
SMSP high flow cat
Apexi N1 exaust (loud as **** now)
AEM CAI
AEM Fuel Rail
AEM Fuel Filter
Stock fuel regulator (Lawance was nice enough to lend me his because my dumbass forgot to bring the nipples to change in my AEM fuel regulator)
Skunk2 Stage 1 Cams
Skunk2 Cam Gears
Skunk2 obdi harness
Hondata s200 with launch control and WOT shifts (thats fun!!)
Hondata intake manifold gasket
Sun Auto Grounding kit
Mobil one 5W-30 freash oil
New NGK Iridium IX's
on my final run i laid down 181.4 HP and 128.4 TQ (all SAE corrected on a dynojet)
Big thanks to everyone on the this board for all their help. the car is a kick in the pants to drive and it makes you want to drive at WOT all the time. I will be going to the drag strip to see what im pullling now on wedsday and will post up the results. all comments or suggestions are welcome.
Future mods will be injectors( im running 100% duity cycle on mine), jim fab motor mounts and traction bar
Modified by TypeRPaul at 11:17 AM 8/16/2004
Modified by TypeRPaul at 5:56 PM 8/16/2004
Old Aug 16, 2004 | 09:11 AM
TypeRPaul's Avatar
Default Re: TypeRPauls ITR finally hits the Dyno!! Graph inside (TypeRPaul)
holy carp...how do i resize?
Old Aug 16, 2004 | 10:17 AM
TypeRPaul's Avatar
fixed
Old Aug 16, 2004 | 10:47 AM
Bbasso's Avatar
looks like your going to be spending more money on more gas
have fun!
Old Aug 16, 2004 | 10:50 AM
Sinbro2's Avatar
Default Re: TypeRPauls ITR finally hits the Dyno!! Graph inside (Bbasso)
pretty decent #'s!
Old Aug 16, 2004 | 10:59 AM
TypeRPaul's Avatar
thanks all...my gas milage actually is better than it was before i got tuned...duh, but when i have it at wot all the time, i could watch it go down...lol
Old Aug 16, 2004 | 11:01 AM
Bbasso's Avatar
Default Re: (TypeRPaul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">but when i have it at wot all the time, i could watch it go down...lol</TD></TR></TABLE>
Thats what I'm talking about
step on the gas
Old Aug 16, 2004 | 01:17 PM
JinDIESEL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">duh, but when i have it at wot all the time, i could watch it go down...lol</TD></TR></TABLE>
pedal to the metal!
Old Aug 16, 2004 | 01:20 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Those numbers seem low to me...and where is the AEM hump?
Old Aug 16, 2004 | 02:13 PM
skunked's Avatar
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">Those numbers seem low to me...and where is the AEM hump?</TD></TR></TABLE>
It does seem a little low....
Old Aug 16, 2004 | 02:23 PM
integrasi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">Well i finally go everything done for my mild street set up and got it tuned by Lawrence of DSR (http://www.dynospotracing.com/) in San jose. Big to Austin for recomending him . Now onto my set up:
SMSP high flow cat
AEM CAI
AEM Fuel Rail
AEM Fuel Filter
Skunk2 Stage 1 Cams
Skunk2 Cam Gears
Skunk2 obdi harness
New NGK Iridium IV's
Modified by TypeRPaul at 11:17 AM 8/16/2004</TD></TR></TABLE>
huh??? when did NGK started to make iridium IV????? j/k not bad #
Old Aug 16, 2004 | 02:45 PM
EMO-anthony's Avatar
Good numbers!
Old Aug 16, 2004 | 03:07 PM
Nishant's Avatar
Default Re: TypeRPauls ITR finally hits the Dyno!! Graph inside (THAiGuYDc2)
looks good
Old Aug 16, 2004 | 03:17 PM
1GreyTeg's Avatar
Betcha it's all due to the following and the cams are just along for the ride
Old Aug 16, 2004 | 04:56 PM
TypeRPaul's Avatar
what should the #'s be if they are low? my tuner saitd it is probably closer to 185, but since the car has been on the dyno you usually loos a bit of hp on a hot motor
Old Aug 16, 2004 | 05:00 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">what should the #'s be if they are low? my tuner saitd it is probably closer to 185, but since the car has been on the dyno you usually loos a bit of hp on a hot motor</TD></TR></TABLE>
don't worry about absolute # value. #'s vary between different dynos.
what's important is that you gained ~21.x hp and ~20ft-lb of torque. that is a heck of a gain, i'd say. enjoy your car!
Old Aug 16, 2004 | 05:58 PM
CA6VTEC's Avatar
Default Re: (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">
what's important is that you gained ~21.x hp and ~20ft-lb of torque. that is a heck of a gain, i'd say. enjoy your car!</TD></TR></TABLE>
<FONT COLOR="royalblue"> Best Reply yet..
Excellent #'s IMO, especially for a mild setup. Enjoy!
</FONT>
Old Aug 16, 2004 | 06:06 PM
Sukebei Oni's Avatar
i would agree that your numbers should be a little higher, but it could be related to just being a hot day. i have a GSR with ITR cams/mani and mild bolt-ons, and I dynoed 172 at DSR. with your higher compression and more aggresive bolt ons, i would expect closer to 190whp. also it looks like you could lower the VTEC point a little so that there isn't such a surge when it comes on. maybe to around 5200-5300 rpm.
Old Aug 16, 2004 | 07:13 PM
Justin Klemgold's Avatar
May I ask how much you spent on all those parts?
Old Aug 16, 2004 | 07:48 PM
an2ny888's Avatar
what cam gear settings did you use?
Old Aug 16, 2004 | 08:06 PM
obd2gsr's Avatar
nice #'s
i wish the dynojet would read all the way through the chart, but eh, what can you do!
looks great, and i wish i could have gotten my hondata tuned, but the lawrence was sick the day of my appointment and flaked out on me!
Old Aug 16, 2004 | 08:40 PM
Rob :190:'s Avatar
Default Re: (Sukebei Oni)
one day, in a new land, people will stop making asinine comparisons of peak numbers...
Old Aug 16, 2004 | 09:32 PM
obd2gsr's Avatar
Default Re: (Rob :190:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">one day, in a new land, people will stop making asinine comparisons of peak numbers...</TD></TR></TABLE>
yeah... and maybe 1/4 mile/track times will mean something
i swear, fuggin' bench racers... maybe he hit his 181 like 5 seconds faster than another engine
Old Aug 21, 2004 | 10:07 AM
TypeRPaul's Avatar
Default Re: (obd2gsr)
Just to update on my 1/4 mi test with the new set up......disapointed best et i hit was a 14.8 just an off night all around....when i i showed up it was nearly 100 degrees and i was just way off as a driver....really need to practice the three step launch and shifts more...will go again when the weather is a bit better, i have my traction bar and motor mounts installed and my dent is removed...let me know if u want me to post up my slips...they are sad though
Old Aug 21, 2004 | 10:12 AM
obd2gsr's Avatar
it's not a big deal about those track #'s... they'll improve the more often you hit the track. to you for having the ***** to do it correctly!
