88 crx si idle problem!
scenerio..
88 crx si w/ a newer motor installed..
Timing Is On..
Good idle when 1st started for 15-20 min...
Then Idle gets rough for 5-10 min...
Then Car Shuts Off..
I checked all the vacuum lines w/ ether! no probs there!
NO OVERHEATING BUT FANS DON"T KICK ON!
WHAT IS WRONG??
Timing Is On..
WHAT IS WRONG??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">Does it run okay at high speed?
fs</TD></TR></TABLE>
Ok what about if you hold the gas pedal, will it shut off?
fs
fs
Is it possible that your cat may be clogged up?
reason is that if your exhaust gases cannot escape efficiently, then backpressure builds up and dies out the engine..
But now, since this is a new install, maybe you installed something incorrectly also and that will be hard to diagnos from here.
fs
fs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LIFER »</TD></TR><TR><TD CLASS="quote">i will try that..if you think of anything else let me know!
thanks</TD></TR></TABLE>
try fuel pressure, sounds like your getting too much fuel
