CRX Swap Shortshifter/Shift Linkage question?
hi guys, I have an 88 CRX Si, and I've swapped in a 93 LS and tranny. now everything in the swap was stock, meaning LS motor, LS tranny, thats it. I want to know first, what kind of tranny is it (tranny code), and what kind of shortshifter do I buy, one for a CRX? or an LS? also, where online can i get already made shiftlinkages shipped to my door. I can do the rest. Thanks!
Your best bet would be to get a HASPORT Linkage. http://www.hasport.com
and then you would get an Integra Short Shifter.
Heres my Hasport Linkages w/GSR Short Shifter + ES Bushings
Modified by QUiKSR20 at 1:03 PM 8/16/2004
so would you need a b16 shortshifter if i were using a y1 b16 sir tranny from a jdm crx on a b18c motor in my crx?
Any B-Series short shifter will work.. Possably even a D-Series Shifter but im not positive on that I would just stick with a B and you cant go wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUiKSR20 »</TD></TR><TR><TD CLASS="quote">Any B-Series short shifter will work.. Possably even a D-Series Shifter but im not positive on that I would just stick with a B and you cant go wrong.</TD></TR></TABLE>
I used a d series short shifter when I swapped in my b16a. I already had the shifter with my previous engine and trans and I just switched it over to the hasport linkage during the swap. Works perfectly.
thanks for the the info QUiKSR20! so I get a hasport 88-91 CRX shift linkage (which fits any b-series in a CRX) and then an what year integra shortshifter? Also for bushings, what is recommended? I want REALLY tight nit bushings that i cant even wiggle the shifter for anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFoutkast »</TD></TR><TR><TD CLASS="quote">thanks for the the info QUiKSR20! so I get a hasport 88-91 CRX shift linkage (which fits any b-series in a CRX) and then an what year integra shortshifter? Also for bushings, what is recommended? I want REALLY tight nit bushings that i cant even wiggle the shifter for anything
Im just running ES Shifter bushings they go by B or D series not chassis. So just get the B-series ones for like $10-$15 online and get the shifter for
an Integra and your set. Should make for a nice setup.
</TD></TR></TABLE>Im just running ES Shifter bushings they go by B or D series not chassis. So just get the B-series ones for like $10-$15 online and get the shifter for
tRex99
Dec 21, 2004 12:02 AM
