will my stock cx 1994 radiator work with a b16 sir II swap in it?
Old Aug 15, 2004 | 08:36 PM
racekar's Avatar
Default will my stock cx 1994 radiator work with a b16 sir II swap in it?
or do i need to get a new radiator?
Old Aug 16, 2004 | 06:08 AM
jbscivichb92's Avatar
Default Re: will my stock cx 1994 radiator work with a b16 sir II swap in it? (dchung1)
i have a b16a sirII and i'm using my stock cx radiator. it isn't overheating or anything but i wanna put a bigger radiator because it gets pretty hot. the cx radiator works just fine though.
Old Aug 16, 2004 | 07:16 AM
racekar's Avatar
thanks!
Old Aug 16, 2004 | 01:02 PM
smart monkey's Avatar
the cx one can work but is prone to leaking. I sell and use the koyo dual core dohc radiator so the hoses match up to the radiator outlets so no leaks.
Old Aug 16, 2004 | 01:42 PM
vtec69's Avatar
ive used a stock rad and worked fine
Old Aug 17, 2004 | 05:41 AM
Default Re: will my stock cx 1994 radiator work with a b16 sir II swap in it? (vtec69)
i bought some big to small pipe adapters at the hardware store and some hose clamps to make the sir hoses fit the cx radiator.
Old Aug 17, 2004 | 11:46 AM
EK_HYBRID_'s Avatar
Default Re: will my stock cx 1994 radiator work with a b16 sir II swap in it? (jbscivichb92)
I also used my stock radiator on my car and have had no problems....but my buddy w/ an EG Hatch used his stock radiator and he is having some problems with leaking....I would get an aftermarket radiator i.e Koyo/Fluidyne so you don't have to deal w/ any leaking later on. Hope that's any help
WhiteOnRice
13
Oct 28, 2007 06:57 PM
90gs
Jan 22, 2005 10:31 PM
EGsex
Dec 22, 2002 09:49 PM
Stop the Beast
12
Mar 14, 2002 12:19 PM
