Dyno session... What a disappointment!
Old Dec 1, 2001 | 06:37 PM
S&P500ITR's Avatar
New User
Default Dyno session... What a disappointment!
I was expecting higher numbers, especially considering that some R’s are putting down similar numbers with only a few bolt-on modifications. I thought I would have been at least 180 with my mods below.
My current modifications are as follows:
AEM CAI
JDM DC 4-1
Test pipe
Toda Spec A
Toda Cam gears
Bored throttle body 64.5mm at the plate/70mm at the opening
AEM adjustable fuel pressure regulator
Did a compression test before the dyno and was at 240 accross all 4
Future mods:
I will have a skunk ecu and vafc shortly. Do you think 180’s is unrealistic with tuning, considering I am only at 175 now?
[Modified by S&P500ITR, 9:09 AM 12/15/2001]
Old Dec 1, 2001 | 09:19 PM
Mike K's Avatar
Default Re: Dyno session... What a disappointment! (S&P500ITR)
whoa. sorry dustin. you should have done better than that.
go OBD1 and your power will go to low to mid 180s easily.
Old Dec 1, 2001 | 09:37 PM
FSTASNTZ's Avatar
Both the ECU and V-AFC should help, your A/F ratios are all over the place. Looks like my car when it had six, yes, 6, bad intake valves...
Jason
Old Dec 2, 2001 | 12:28 AM
Black R's Avatar
25 Year Member
.....i'd say try the vafc first. you may not need the skunk2 ecu. Use that $ for dyno time. I posted a thread on street tuning not too long ago. Use that on the dyno and it'll definitely help you. I'd say ~15 passes and you'll be at ~185whp easy...
Old Dec 2, 2001 | 01:03 AM
Mike95lude's Avatar
Default Re: Dyno session... What a disappointment! (Black R)
I'm going to have to agree and say that the V-AFC will help out a lot, you should have no prob hitting 180+.
Old Dec 2, 2001 | 01:07 AM
MiraiZ's Avatar
Default Re: Dyno session... What a disappointment! (Mike95lude)
I noticed that itr's are very sensitive to air temprature and humidity....what was the weather like?
Old Dec 2, 2001 | 05:27 AM
S&P500ITR's Avatar
New User
Default Re: Dyno session... What a disappointment! (MiraiZ)
The ECU has already been bought and paid for quite some time ago same with the VAFC...Just waiting on the OBD1 jumper. The weather was typical FL; humid and 81, but the numbers were SAE. I havn't messed with the cam gear settings, only the fuel pressure due to time constraints. The engine seemed to like 40psi the best anything more/less the power would drop.
Old Dec 2, 2001 | 06:00 AM
nsx-Animal's Avatar
Do you have stock compression?
Old Dec 2, 2001 | 06:34 AM
1fastGSR's Avatar
New User
Default Re: Dyno session... What a disappointment! (ITR-Animal)
tuning is everything.....
untuned cams are worthless. After instaling ITR cam, I gained only 6 whp. My HP was 166 whp after droping the cams without tuning. After tuning, I was making 176 whp, 10 wph more!
YOur A/F looks all messed up
Old Dec 2, 2001 | 07:15 AM
S&P500ITR's Avatar
New User
Default Re: Dyno session... What a disappointment! (1fastGSR)
The cams are at +4/+2 or close to that setting which was recommended to me. My compression is stock, for now.
Old Dec 2, 2001 | 08:08 AM
stick's Avatar
im almost making that much with ITR cams in B18C1 w/ stock TB,compression,bottom end.
i would expect more in ITR with Toda A's
definitely need to tune more
[Modified by stick, 9:08 AM 12/2/2001]
Old Dec 2, 2001 | 08:20 AM
FSTASNTZ's Avatar
Did you have the stock exhaust on? I see the header and test pipe, but no mention of an exhaust. That may actually be hurting you on the top end.
And yes, with a little tuning, things will look better...
Jason
Old Dec 2, 2001 | 08:50 AM
S&P500ITR's Avatar
New User
Default Re: Dyno session... What a disappointment! (FSTASNTZ)
stock exhaust because I haven't decided on which exhaust I wan't. That is something I am picky about...don't wan't a raspy loud exhaust, but at the same time, I don't wan't to pay $900 for a mugen twin loop. Looking for something in the middle like an apexi ws.
Old Dec 2, 2001 | 09:34 AM
FAST94GSR's Avatar
New User
you need an exhaust, any exhaust get a custom one done and save money. Don't be concerned with peak hp numbers, focus on the torque and keeping that flat all the way through. With the vafc you'll be able to keep the af ratio constant.
Old Dec 2, 2001 | 09:38 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Dyno session... What a disappointment! (FAST94GSR)
I'm telling you Dustin, get a bottle. Your car is still better looking that mine
Old Dec 2, 2001 | 10:47 AM
sloppy_seconds's Avatar
Banned
Default Re: Dyno session... What a disappointment! (RealTypeR)
the exhuast will bring your #'s up...but think of goin OBDI and gettin the skunk program...you'll FEEL the difference!
--justin
Old Dec 2, 2001 | 10:57 AM
Xerzex's Avatar
New User
Default Re: Dyno session... What a disappointment! (slowasscx)
2 semi-off topic ?s/comments...
1 - To go OBD1 between the ECU and harness its around $400? just want to get a rough estimate
and
2 - Go Canes!!! Undefeated baby!!
gsr98vtec's Avatar
go obd1, get the vafc, and if you havent done head work then do that as well..a good port and polish always adds to the numbers...with just an ecu and vafc 180's is very possible
Old Dec 2, 2001 | 11:20 AM
Jackson's Avatar
Default Re: Dyno session... What a disappointment! (gsr98vtec)
dont port your type r head. if you do, give it to me and you can port my b16 head.
Old Dec 2, 2001 | 11:42 AM
TypeR0207's Avatar
Default Re: Dyno session... What a disappointment! (Jackson)
Stock exhaust is fine on the R, don't waste your money unless you get a full 2.5" one.
Tuning, tuning, tuning, tuning .... you need to dyno tune it definitely.
With i/h/e/camgears/V-AFC in my '98, I was at 178/126 ....... 175/125 without the V-AFC. You will be in the 180+ range with some good tuning.
Old Dec 2, 2001 | 03:10 PM
98R-641's Avatar
Jason, how do you tell if the valves are bad? What's the characteristics of bad valves is my question??
Old Dec 2, 2001 | 04:03 PM
Total'd GSR's Avatar
New User
RealTypeR... what have you done to your car for 227 whp???
BTW... I see that you and S&P are from Orlando... do you guys meet up ever and if so where? I live like 5 mins from UCF. Let me know. Later.
S&P... where'd you get your car dyno'd? I want to get my VAFC tuned on the dyno but I'm waiting until I get cams and until I can find somewhere to tune it that is knowledgable with imports.
Old Dec 2, 2001 | 04:08 PM
naturalvx's Avatar
Default Re: Dyno session... What a disappointment! (Tanabe'd GSR)
Real Type R is powered by the dark side. NOS. I believe S&P went to Siboneys dyno. Email me wes@titanmotorsports.com or PM me and I can get you thier contact info. I also work at a shop so if you need cams or anything of that nature let me know.
Old Dec 2, 2001 | 04:58 PM
S&P500ITR's Avatar
New User
Tanabe'd GSR:
wes is right, I had the car dynoed at siboneys. The dyno is in-ground which makes setup time a snap. Their rates are fairly decent and the people down there are all right. If you need cams or anything else like that you should hit wes (naturalvx) up, I know he can get jun&skunk and probably most others as well.
Old Dec 2, 2001 | 05:08 PM
New User
Default Re: Dyno session... What a disappointment! (naturalvx)
Wes... you work at Titan, correct? I've been in a few times with my boy Chris Yepez... he has a 92 Talon and he bought his SAFC off of you guys. Do you know his brother Carlos Yepez (silver 99 eclipse GST w/ a 16g)? He's friends with Nero and Bottle and he introduced me to your shop.
BTW... my dad said that he met you a few weeks ago. I don't know why he was at the shop (hopefully he bought me some ****) but he specifically told me that he met you. Does the name Don Lisenby ring any bells?
S&P... how much did Siboneys charge you? Do they use a wideband O2 sensor? Do they do work with AFC's? Thanks bro!
