throotle response?
Old Aug 15, 2004 | 07:54 PM
vmm's Avatar
vmm
Default throotle response?
ok. i step on the acc. pedal, and the motor takes prolly like half a sec to rev. it doesnt rev rite wen i step on it.. how can i fix this? could it be timing? im not sure. or is it sposed to be like dat? i gotta doch Zc. thanks'
Old Aug 15, 2004 | 08:30 PM
vmm's Avatar
vmm
Default Re: throotle response? (vmm)
sumwon juss say sumfin plz.
Old Aug 15, 2004 | 09:54 PM
The ZC's Avatar
It could be timing/ecu/hole bunch of otherstuff
Do u hear the vtec kicking in?
Old Aug 15, 2004 | 10:13 PM
DJ_SaNdOz's Avatar
Default Re: throotle response? (The ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The ZC &raquo;</TD></TR><TR><TD CLASS="quote">It could be timing/ecu/hole bunch of otherstuff
Since when did Honda make a VTEC equipped DOHC ZC?
Old Aug 15, 2004 | 10:41 PM
wannabe_si's Avatar
Default Re: throotle response? (DJ_SaNdOz)
and his name is ZC
Old Aug 15, 2004 | 10:43 PM
Malgerus's Avatar
Default Re: throotle response? (wannabe_si)
Could be a misdjusted/bad TPS.
Old Aug 15, 2004 | 11:02 PM
spaceman's Avatar
adjust your throttle cable(take out the slack)...get a tune-up..check your timing..zzz and a bunch of other stuff,hehe
Old Aug 15, 2004 | 11:13 PM
The ZC's Avatar
it was a joke lol...
Old Aug 16, 2004 | 02:57 AM
siR cr-x's Avatar
Default Re: (The ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The ZC &raquo;</TD></TR><TR><TD CLASS="quote">it was a joke lol...</TD></TR></TABLE>
sure you were
Modified by siR cr-x at 4:18 AM 8/16/2004
Old Aug 16, 2004 | 11:28 AM
EF_LSVtec's Avatar
Default Re: (siR cr-x)
check your timing and vacuum lines (no open lines), make sure that they're in order. Is this a stock motor? If not, what did you replace? usually a throttle body that's wayt too big would cause the motor to have a slight delay in throttle response.
Old Aug 17, 2004 | 05:30 PM
vmm's Avatar
vmm
Default Re: (EF_LSVtec)
evrythings stock, but ill check at u guys sed..
Old Aug 17, 2004 | 05:49 PM
Targa250R's Avatar
be professional
Do you have a cold air intake?
Old Aug 17, 2004 | 05:53 PM
vmm's Avatar
vmm
Default Re: throotle response? (Targa250R)
nope, just a cheap *** short ram intake
civic_frank
Aug 16, 2008 11:14 PM
jeezyskillz
11
Jan 6, 2007 11:38 AM
FastHatch90
11
Apr 2, 2006 10:18 PM
jdmEF8racer
34
Mar 27, 2006 10:28 PM
sicx
54
Mar 17, 2004 09:03 AM
