ABS light on 96 GS-R
Old Dec 1, 2001 | 06:13 PM
Crowbar's Avatar
Default ABS light on 96 GS-R
I just picked up a 96 GS-R and I've noticed that if im driving continously for more than 20 - 30 minutes my ABS light pops on. Any ideas as to what could be causing this and how to fix it? There isn't any snow in Wisconsin yet so I cant actually test to see if the ABS stops working at that point.
Old Dec 1, 2001 | 11:48 PM
integra15's Avatar
Default Re: ABS light on 96 GS-R (Crowbar)
Does the brake pedal travel too far when pressed? If so you could need fluid, or it could be that a caliper is stuck closed.
Old Dec 2, 2001 | 12:45 AM
LostGsr's Avatar
You need to jump the service connector and find out the code it gives you for the abs system. That way you can pinpoint the problem in the abs.
Old Dec 2, 2001 | 12:55 AM
Joe92RT's Avatar
Default Re: ABS light on 96 GS-R (LostGsr)
Just curious, does anyone know what the different codes mean? If so, could you please post them? Also, is the harness that needs to be jumped, just a 2 wire harness, or do you need to figure out which pins to jump? Thanks! (Cars in the shop, so I can't go out and look right at the moment)
--Joe
Old Dec 2, 2001 | 01:51 AM
Kelvin96GSR's Avatar
25 Year Member
Default Re: ABS light on 96 GS-R (Joe92RT)
1 Primary O2 Sensor
Open or Short in O2 sensor circuit, bad
Primary O2 sensor
3 Manifold Absolute Pressure Sensor
Open or short in MAP sensor circuit,
bad MAPS
4 Crankshaft Position Sensor
Failed sensor or timing belt slipped, bad
CPS
5 Manifold Absolute Pressure Sensor
Reading too low or too high, bad MAP
6 Engine Coolant Temp
Circuit Reading too low, high, short or open, bad ECT
7 Throttle Position Circuit
Reading too high, low, short or open,
bad TPS
8 Crankshaft Position Sensor/ Top Dead Center Sensor/
Cylinder Position Sensor/
CKP/TDC/CYP sensor circuit
disconnected, open or short. Bad TDC
sensor.
9 Cylinder Position Sensor
Open or short in CYP circuit, bad CYP
sensor
10 Intake Air Temperature Sensor
Short or open in AIT circuit, bad AITS
13 Barometric Pressure Sensor Circuit
Bad ECM (Barometric sensor)
14 Idle Control System Malfunction
Bad IAC valve, bad fast idle thermo
valve, Throttle body
16 Fuel Injector
Problem with fuel injector circuit or injector
17 Vehicle Speed Sensor Circuit
Short or open in VSS circuit, bad VSS
20 Electrical Load Detector Circuit
Short or open in circuit, bad ELD
22 VTEC System Malfunction
Short or open in VTEC circuit, bad
VTEC solenoid valve, Bad VTEC
pressure switch
23 Knock Sensor Circuit
Short or open in Knock Sensor circuit,
bad Knock Sensor
30 A/T FI Signal A high/low input
Bad AFSA line, TCM
31 A/T FI Signal B high/low input
Bad AFSB line, TCM
41 Primary Heated O2 Sensor Heater
Open or short in Primary O2 sensor
heater circuit
45 System too lean/rich
Fuel supply system, Primary O2 sensor,
MAP sensor, contaminated fuel, valve
clearance, exhaust leakage
54 Crankshaft Speed Fluctuation Sensor
Open or short in CKF circuit, bad CKF
sensor
61 Primary Heated O2 Sensor
Slow response, bad O2 sensor, exhaust
leak
63 Secondary Heated O2 Sensor
leak
65 Secondary Heated O2 Sensor Circuit
Open or short in secondary O2 sensor
circuit
67 Catalyst System Efficiency
System below threshold, bad catalytic
converter
70 Automatic Transaxle
A/T transmission, A/T FI data line,
TCM, ECM
71 Random Misfire (Cyl 1)
Ignition system, fuel supply system, MAP
sensor, IAC valve, contaminated fuel,
lack of fuel, fuel injector, fuel injector
circuit, low compression, valve clearance
72 Random Misfire (Cyl 2)
73 Random Misfire (Cyl 3)
74 Random Misfire (Cyl 4)
86 Engine Coolant Temp Circuit
Bad ECT sensor, bad cooling system
90 Evap Emission Control System Leak
Fuel cap loose, poor vacuum connection,
fuel tank, fuel tank pressure sensor,
EVAP bypass solenoid valve, EVAP
2-way valve, EVAP control canister
vent shut valve, EVAP canister, EVAP
purge control solenoid valve
91 Fuel Tank Pressure Sensor Circuit
Open or short in FTP circuit, Bad fuel
Hope that helps!
Old Dec 2, 2001 | 11:18 AM
LostGsr's Avatar
Default Re: ABS light on 96 GS-R (Kelvin96GSR)
The list Kelvin posted are the CEL codes. The list you want is from a different set of codes, especially for the ABS system. I don't have my Helm right now but as soon I get home I look it up.
Old Dec 2, 2001 | 11:31 AM
25 Year Member
ah ****, I'll get my helms out again tonight and post up the right codes sorry...
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
BoBo Racing
Jun 5, 2008 01:31 PM
rollercosta123
Nov 25, 2005 12:09 AM
TerribleOne
Mar 19, 2003 10:59 AM
Dirt
Jun 6, 2002 05:16 AM
