in need of some help guys...:\
Old Aug 15, 2004 | 06:15 PM
sd.coupe's Avatar
Default in need of some help guys...:\
heres the deal..... turn the car over... nothing.... maybe if im lucky i'll get some clicking sound when turning over the car... or it will just turn over and do nothing..... im really getting tired of jump starting my car everywhere i go.....
car starts perfect when i jump start it... and i dont want to lose a arm and a leg at the repair shop... if it's something stupid and easy. ... i probaly could have searched.... but im in need of some info now.. i have work tomorrow.... and if not... i guess im busting out the skateboard to work. brand new starter... brand new batt.... thinking it's the alt. but would it be the volt reg.?....
THANKS GUYS
Old Aug 15, 2004 | 06:21 PM
Gfowler's Avatar
Default Re: in need of some help guys...:\ (sdhatch)
i will help you get your car going if you help me get my 91 si sold by placeing it in the classifides i am a trial user and cant place adds help me and i will help you. i am the Head Tech a Intense Mototsports. i can get it done if you can help me get it done thanks
Old Aug 15, 2004 | 06:24 PM
sd.coupe's Avatar
yea for sure.. give me the info!
Old Aug 15, 2004 | 06:48 PM
sd.coupe's Avatar
bump! still need help!
Old Aug 15, 2004 | 09:31 PM
OreoEF8's Avatar
Default Re: (sdhatch)
i had the same problem with my b16. it turned out to just be a bad alternator. no big deal. my car did the same thing, just a clicking noise when i turned the key. battery was dead because the alternator wasnt charging it. new alternator fixed the problem....hope this helps
Old Aug 16, 2004 | 06:49 AM
sd.coupe's Avatar
thanx man! i'll see if thats the prob.
Old Aug 16, 2004 | 01:34 PM
IronOutlawz's Avatar
Also check you battery terminals. Sometimes if they are corroded it will cause a problem like that.
Old Aug 16, 2004 | 02:04 PM
Lucias_D's Avatar
First I suggest checking your battery terminals. Make sure they are corrosion free and making proper connectivity. Next Check your ground on your battery. Grounds cause way more things then you think. Then Check the ground and positive connection to your starter. This is a popular reason why cars won't start. Finally, I would go with what deliciousrex said, except check the output of your alternator before you put on a new one. Make sure it's working properly and producing proper output. If you are still having problems post back, but one of those causes is probably the reason your car won't start.
Old Aug 16, 2004 | 03:27 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: in need of some help guys...:\ (Gfowler)
Gfowler,
Once you've posted enough 6 or 7 times, you should be able to post in the classifieds.
Old Aug 16, 2004 | 04:13 PM
vitrox's Avatar
takes 20 days to not be a trial user.
Old Aug 16, 2004 | 05:33 PM
shawn_crx's Avatar
Default Re: (vitrox)
Take the car to a parts shops ( karegen, autozone, etc. ) Have the test the battery and alternator. I think it's free of charge.
Old Aug 16, 2004 | 05:53 PM
Cornwhiskey's Avatar
most of the time when the alt goes bad the battery light on the gauge cluster will come on is that coming on when the car is running ...
shanon ugalde
Oct 11, 2015 04:54 PM
AnDy327
Oct 26, 2007 12:26 PM
thehondabuddy
Jan 28, 2004 09:58 PM
