Fuel economy in your Boosted B18C
Old Aug 15, 2004 | 03:56 PM
Turbo E's Avatar
Default Fuel economy in your Boosted B18C
i recently went camping and got 500kms (310 Miles) off a EG fuel tank (45-50L?) this is with 3 people in the car and a trunk FULL of gear.
just want an idea of what other people are getting.
Modified by Turbo E 604 at 8:49 AM 8/16/2004
Old Aug 15, 2004 | 04:16 PM
toolowsol's Avatar
Default Re: Fuel economy in your Boosted B18C (Turbo E 604)
310mpg huh..... Are you sure you don't mean 310 miles / tank
Old Aug 16, 2004 | 07:49 AM
Turbo E's Avatar
lol sorry, typo
Old Aug 16, 2004 | 07:55 AM
toolowsol's Avatar
Default Re: (Turbo E 604)
Well i've only been boosting for 3 days, but damn, gas isn't going as far as it used to LOL...
But I've got my maps tuned to where if I stay out of boost, fuel economy is the same as stock, but once your boosting, you can say good bye to MPG If you want, once my uberdata map is done, I can send it to you, or burn you a chip with it, It will be fully tuned part and WOT, b18c with skunk2 intake manifold, 64mm tb, SC34 turbo and DSM 450cc injectors
Old Aug 16, 2004 | 08:14 AM
donkiman's Avatar
Default Re: (toolowsol)
I was using 94 octance and hammering for a while one night and I found that I didn't go through nearly as much gas as I would have though. but I have no idea of numbers. b18c1 turbo in 97 civic.
Old Aug 16, 2004 | 12:35 PM
95stangkillah's Avatar
If I stay out of boost, I can get 30 mpg on high way driving. 310 miles per tank doesn't tell me much, because most eg fuel readings from teh dashboard are off a bit and since I don't have a fuel light I dunno when I absolutely need to fill up. for instance I know I need to fill up about 8 Gal when I hit about 230-40 miles on the odometer.
Does anybody have a crome/uberdata tuned map for the very common stock block GSR with 45occ's and a Drag III kit?
Old Aug 16, 2004 | 12:38 PM
toolowsol's Avatar
Default Re: Fuel economy in your Boosted B18C (95stangkillah)
stange killer, I will have a tuned b18c1 map for a stock engine with custom kit, Should be done in a week or two, email me if you want me to send it to you (uberdata)
Old Aug 17, 2004 | 08:36 AM
Default Re: Fuel economy in your Boosted B18C (toolowsol)
what's the difference between a stock motor wiht Drag kit map vs your custom kit map? Would that be safe on my car since we run slightly different setups? I appreciate the help but I want to know if it's safe or not. Thanks
Old Aug 17, 2004 | 09:21 AM
boosted92's Avatar
Only accurate way to measure gas mileage is to fill it up, reset trip odo or record odo number, drive for however long you want to, then fill it up to the brim again. Record the KM's and how much gas you put in and voilla, gas mileage. When you think you're running on empty there could still be a litre or two of gas left in the tank, so that isn't exactly accurate.
Stubby3si
Engine Management and Tuning
Mar 16, 2009 11:04 PM
Problemo
15
Jan 16, 2006 11:17 AM
EG6-B18C
Aug 24, 2001 11:19 AM
