97 EX 4spd Auto-trans downshift - not
Old Aug 15, 2004 | 03:29 PM
alotawatts's Avatar
Default 97 EX 4spd Auto-trans downshift - not
Our 97 EX Civic D16Y8 with an auto transmission 4 spd. does not always downshift when we put the pedal down (passing gear) on hills in town 30-40 mph.
There is 76k miles on the car. It runs well and in general shifts well ..... Is this a Take to the Dealer for specialized transmission testing equipment kind of problem ?
Thanks
Old Aug 15, 2004 | 03:31 PM
D16y8-T's Avatar
Default Re: 97 EX 4spd Auto-trans downshift - not (alotawatts)
When was the last time you changed your transmission fluids?
Old Aug 15, 2004 | 03:37 PM
alotawatts's Avatar
Default Re: 97 EX 4spd Auto-trans downshift - not (D16y8-T)
A fluid-flush change is no doubt due.......but is'nt it more likely a throttle body or transmission sensor or similar.....? Just a fluid change sounds too easy-lucky of a fix for me. ?
Old Aug 15, 2004 | 03:40 PM
D16y8-T's Avatar
It could be several things, but your best bet is to start with the fluid as you mentioned its due. Friend of mine was having similar problems as you described and he simply put in some Honda ATF and it fixed his problem (he too hadn't changed his ATF for a long time).
xkitex
Dec 9, 2013 01:00 AM
black7thgenls
Jan 17, 2012 12:21 PM
mccadr
Mar 2, 2005 02:30 PM
97exer
Jun 23, 2004 07:35 PM
