p28 w/boost
Old Aug 15, 2004 | 03:23 PM
n1_ek's Avatar
* B A N N E D *
Default p28 w/boost
I was wondering if i would be able to run a p28 w/ a p30 program installed with turbo? Because ive heard issues of running a p28 with like a skunk2 program and their motors have blown up. but since this is a stock program will it be fine?
Old Aug 15, 2004 | 04:55 PM
eg6ajk's Avatar
Default Re: p28 w/boost (ryan819)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan819 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if i would be able to run a p28 w/ a p30 program installed with turbo? Because ive heard issues of running a p28 with like a skunk2 program and their motors have blown up. but since this is a stock program will it be fine?</TD></TR></TABLE>
depends on the program. if the knock sensor on the P30 is disabled then it should work without a problem. people who run stock motors with RACE programs and rev limits few thousand rpm over stock are simply asking to have issues. match the chip to the motor and you'll have no problems.
btw. I can do boost programs for P28 check sig
Old Aug 15, 2004 | 04:57 PM
ATS*Mark's Avatar
OG triple OG
Default Re: p28 w/boost (eg6ajk)
yup just make sure you get a boost program . i made mine with uberdata . of course if you run an all motor program with a turbo motor youll blow it , common sence.
Old Aug 15, 2004 | 09:20 PM
n1_ek's Avatar
* B A N N E D *
yeah i actually checked out your site and i saw that you had a stock p30 program you can burn for a p28, so that got me wondering if i could just use my old p28 and chip it to the p30 specs (just stock program, no changes to the p30 prog) and later on run it with my turbo setup.
PostSRT
Jan 16, 2008 07:26 PM
lsvtec2000
Jul 26, 2007 09:47 AM
