Will EK LCA's fit an EM1?
Simple question. Just needs a simple answer. I'm looking at some aftermarket LCA's for my EM1 and keep coming across them for the EK. I'm not too sure about the difference in suspension between the regular 96-00 civics and the 99-00 Si's. So if anybody wants to chime in, I'd appreciate it.
rears are all the same. all interchangable, EK is simply chassis code that most use to describe 96-00 civics
front are slightly different on the h-backs/sedans then on the Si/SiR coupe but certinaly interchangable.
Thanks. I knew that the front suspension was a bit different than the regular civics. Wasn't too sure about the rear. The reason I'm asking is because I'm looking at these
http://cgi.ebay.com/ebaymotors...=true
it just says 96-00 Honda Civic (All models). Also, it's been a while since I've crawled under the car (installed Tein SS's about 2 years ago). I don't remember where the holes for the rear sway bar connecting points were. Just by looking at the pic of the Megan arms can you tell me if they're there? Thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">EM1 LCAs have the holes for your rear sway bar, where EK (CX/DX, etc) LCAs don't have it. but yes they will fit.</TD></TR></TABLE>
on the 96-00 civics here in canada have the swaybar holes in the rear. actually rear stock EK LCA is the same for both sides.
Actually my dx has the holes, i didn't think it would but i checked and they're there
