air conditioning not blowing hard enough
Old Aug 15, 2004 | 01:07 PM
pezzy's Avatar
Default air conditioning not blowing hard enough
i have a 93 dx with jdm b16 swap and i swapped out the compressor to a 97 gsr compressor and refilled the freons. the air is cold and everything but it doesnt blow out hard enough so the car isnt really cold, if i put it on max it blows out about half speed of what other cars do, what could be the problem
Old Aug 15, 2004 | 01:09 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: air conditioning not blowing hard enough (pezzy)
try blowing out the leaves and crap thats sitting in the blower motor, and evap inlet.
Old Aug 15, 2004 | 01:18 PM
dohcMONSTER's Avatar
Default Re: air conditioning not blowing hard enough (Built B16A)
smack her upside the head
Old Aug 15, 2004 | 01:47 PM
pezzy's Avatar
where is the blower motor and evap inlet
Old Aug 15, 2004 | 01:48 PM
Archidictus's Avatar
Unceasing Measure
Default Re: air conditioning not blowing hard enough (sohcMONSTER)
Now, did you actually put Freon (R12) in it? If so, that's going to upset the balance of things. If you put R134a in it (1,3,4 Tetraflouroethane), your blower motor is either clogged or broken.
Old Aug 15, 2004 | 02:21 PM
Hatchd's Avatar
Default Re: air conditioning not blowing hard enough (Archidictus)
this may seem like a stupid answer but ive dont it numerous times. Check the vent on the top of your dash. If it is open the air seems like it's not even on. Close it and you will notice a difference. If not, go with the other guys solutions.
Old Aug 15, 2004 | 02:39 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Now, did you actually put Freon (R12) in it?</TD></TR></TABLE>
Not so. Freon is actually a brand name that's trademarked by DuPont. It's their version of refrigerants. Not just R12. Just thought I'd throw that in there.
Anyway, like the guys above mentioned, look in your blower box located under the passenger side of the dash. It's a black plactic box that houses the blower motor and heat and AC coils. Open it up. There's a good chance you have some leaves and other junk stuck inside there.
Old Aug 15, 2004 | 02:41 PM
Unceasing Measure
Default Re: air conditioning not blowing hard enough (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Not so. Freon is actually a brand name that's trademarked by DuPont. It's their version of refrigerants. Not just R12. Just thought I'd throw that in there.
Anyway, like the guys above mentioned, look in your blower box located under the passenger side of the dash. It's a black plactic box that houses the blower motor and heat and AC coils. Open it up. There's a good chance you have some leaves and other junk stuck inside there.</TD></TR></TABLE>
True, but I was referring to it as Freon because that's what the original poster cited it as .
Old Aug 21, 2004 | 12:09 PM
pezzy's Avatar
i took out the blower motor by taking 3 screws out underneath the glovebox...there were a few leaves and i took them out and put them in..but there seems to be no improvement, what else could be the problem
Old Aug 21, 2004 | 12:21 PM
pezzy's Avatar
also the middle vent on top closest to the windshield does not work...it used to...
Old Aug 21, 2004 | 01:02 PM
ej1 pilot's Avatar
your vents may be clogged, or your blower motor might be bad
Old Aug 21, 2004 | 01:38 PM
BatuKing's Avatar
Default Re: air conditioning not blowing hard enough (Art In Motion)
It can be your blower resistor pack.. blower motor.. check to see your voltage drops accross the motor as you change to each item.
get a helm and go to page 21-9 ( 882 in PDF ) and do some troubleshooting.
Pooby88
Aug 29, 2009 07:27 PM
Dj Skidz7
May 5, 2009 09:48 AM
SedanCruiser
Aug 1, 2007 10:37 AM
TekNinja23
Jul 11, 2003 08:26 AM
B18C1 '96 Coupe
10
Mar 9, 2003 12:01 PM
