put my front end on
Old Aug 15, 2004 | 11:35 AM
spoon063's Avatar
Default put my front end on
im lookin for someone to weld on my jdm t-bar (top part of the rad support) for my front end, i just moved here so i dont have any connections, located in 949 OC socal, anyone who could help me out would be appreciated, thanks
Old Aug 16, 2004 | 12:56 AM
spoon063's Avatar
Default Re: put my front end on (spoon063)
bump
Old Aug 16, 2004 | 08:31 AM
spoon063's Avatar
Old Aug 16, 2004 | 09:40 PM
L-CON1's Avatar
Old Aug 17, 2004 | 07:13 AM
Ekasey's Avatar
Default Re: put my front end on (fab1)
You might wanna try MOB works they are in orange, there a good custom paint and body shop.
Old Aug 17, 2004 | 11:46 AM
spoon063's Avatar
Default Re: put my front end on (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">You might wanna try MOB works they are in orange, there a good custom paint and body shop.</TD></TR></TABLE>
you wouldnt happen to have a # for them would you
Old Aug 17, 2004 | 12:25 PM
Ekasey's Avatar
http://www.mobworks.com/
714-633-9355
Old Aug 17, 2004 | 03:36 PM
spoon063's Avatar
haha i just called, about $150 to weld... 600 if i want my hood/fenders/bumper on, otherwise i have to trailer it out of there
Old Aug 18, 2004 | 08:18 PM
so simple's Avatar
so 150 to weld on the parts? and 450 to put on the body parts? if so, throw the parts in a truck, when theyre done welding go to a parking lot next door and install the body parts urself. assuming with the welding all done, its a bolt on affair from there
Modified by simpleaznx at 8:20 PM 8/19/2004
Old Aug 19, 2004 | 09:31 AM
spoon063's Avatar
Default Re: put my front end on (simpleaznx)
i said screw it and im about to do it myself in an hour or so, i rented a welder from a local place, $30 vs $150 right now im my situation sounds good
Old Aug 19, 2004 | 11:21 AM
so simple's Avatar
let me know how that turns out man, im trying so hard right now to find a friend who can help me do it cause shops are charging a lot to install it, i cant even get close to 150 in my area, my shop said 1k to install and paint front end
Old Aug 19, 2004 | 11:25 AM
spoon063's Avatar
Default Re: (simpleaznx)
im fittin mine right now, ill let you know
Old Aug 19, 2004 | 03:00 PM
spoon063's Avatar
Default Re: (spoon063)
UPDATE: i suck *** at welding
Old Aug 22, 2004 | 08:43 AM
spoon063's Avatar
horrible pic i know
Old Aug 22, 2004 | 08:46 AM
mmuller's Avatar
Mad Scientist
looks good, you should of taken pics of the welds
Old Aug 22, 2004 | 12:06 PM
so simple's Avatar
how long did it take? everything line up correctly on the first try? t-method?
Old Aug 22, 2004 | 12:16 PM
spoon063's Avatar
yeah man, everything lined up great.... even with the fiberglass fenders im using (temporary)... first try, i think the t-bar is a way easier way to go than changing the whole thing... all i did was paint over the stock part so i knew exactly where the new one went... the only downfall i had was using an arc welder without any prior experience, but i got the hang of it
Old Aug 22, 2004 | 01:40 PM
Code Blue's Avatar
so all you really had to do was change the top reinforcement area, and use all of the fenders bumpers bumper support hood, etc?
Old Aug 22, 2004 | 02:06 PM
spoon063's Avatar
Default Re: (Code Blue)
i got the parts from paswordJDM.com, its just the top part and the middle part the hood latch bolts to, all the rest of the radiator support is the same
Old Aug 22, 2004 | 03:27 PM
Dc2 Powered's Avatar
you weld yourself? holy hell u are prostatus haha
Old Aug 22, 2004 | 08:36 PM
Luserkid's Avatar
Default Re: (Dc2 Powered)
I want to see pics of your welds.
Old Aug 22, 2004 | 11:18 PM
dc2_tuner's Avatar
how did you get the t section and how big is it? i just got my front end on the 20th and i need some help!!!!!!
Old Aug 22, 2004 | 11:51 PM
spoon063's Avatar
Default Re: (dc2_tuner)
my welds weren't the prettiest of em all ill try to get some pics up... i got the t-bar from passwordjdm.com, i picked it up since im local i wanna say it was around $220.... i cant remember but its def worth it to go that route
Old Aug 23, 2004 | 04:16 AM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 &raquo;</TD></TR><TR><TD CLASS="quote">my welds weren't the prettiest of em all ill try to get some pics up... i got the t-bar from passwordjdm.com, i picked it up since im local i wanna say it was around $220.... i cant remember but its def worth it to go that route</TD></TR></TABLE>
i think i was quoted less than that for the full radiator support
Old Aug 23, 2004 | 07:52 AM
spoon063's Avatar
the cheapest i found a full brand new one for was 275 but i couldnt pick it up
