Is tig cleaner(less sparks/slag/smoke?)
Justt wondering if using a tig is cleaner than mig as I never see them throwing up any sparks on the tv shows.
Does this mean I could use a tig in my basement without fear of setting the place on fire?
What about the gas does it give off any harmful fumes?
I don't have a garage so its either the basement or outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex »</TD></TR><TR><TD CLASS="quote">Justt wondering if using a tig is cleaner than mig as I never see them throwing up any sparks on the tv shows.
I don't have a garage so its either the basement or outside.</TD></TR></TABLE>
Tig is very clean (Zero slag and sparks and a very small plume of smoke). There is a very small concentrated arc.
As for fumes, I would not do any type of welding without some form of ventilation.
All you need is a small exhaust fan (with the intake hose close to your work) with a hose that vents outside , like this: http://www.mylincolnelectric.c...p=605
yea but with tig u dont want your ventalion close cause tig using a inert gas call argon. and that is your protection of your weld. and if you suck that gas away your weld with be cantaminated and weak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SANKA »</TD></TR><TR><TD CLASS="quote">yea but with tig u dont want your ventalion close cause tig using a inert gas call argon. and that is your protection of your weld. and if you suck that gas away your weld with be cantaminated and weak.</TD></TR></TABLE>
...and argon is more dense than air so it doesn't float upward. It goes down.
My previous welding instructior has been welding every day for 30+ years without any ventilation or health issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fab1 »</TD></TR><TR><TD CLASS="quote">lol, do not weld in your basement. no matter what anyone tells you...
Yup. I'm sure it'd be great fun to asphyxiate yourself.
</TD></TR></TABLE>Yup. I'm sure it'd be great fun to asphyxiate yourself.
