Civic/Integra drum/disk brake lines.
Old Aug 15, 2004 | 05:11 AM
Ajax's Avatar
Default Civic/Integra drum/disk brake lines.
I was looking on ebay and there some brake lines for the 92-95 civic and the 94-00 Integra. I thought when you did the rear disk conversion you had to change the brake lines? I'm guessing that the disk 92-95 civic disk brake and drum brake are different brake lines. But the 92-95 civic disk brake and the 94-00 Integra use the same brake line?
Old Aug 15, 2004 | 05:48 AM
funkfnamna's Avatar
Default Re: Civic/Integra drum/disk brake lines. (Ajax)
the ex coupe and si hatch had rear disks so they would be the same lines as the teg
Old Aug 15, 2004 | 06:29 AM
Ricey McRicerton's Avatar
Default Re: Civic/Integra drum/disk brake lines. (funkfnamna)
Yes, if swapping from disks to drums in the back you have to swap lines. The way they bolt up to the disk/drum is completely different. I used Teg lines on my rear ITR brakes on a 97 hatch.
Old Aug 15, 2004 | 06:38 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkfnamna &raquo;</TD></TR><TR><TD CLASS="quote">the ex coupe and si hatch had rear disks</TD></TR></TABLE>
The non-ABS EX did not have rear discs.
The Si, Si-ABS, and EX-ABS (coupe and sedan) had rear discs.
blu3g
May 21, 2007 09:24 AM
TeggerLS
Sep 19, 2006 06:43 PM
jefe
30
Dec 11, 2004 12:41 PM
streetdreams420
Aug 23, 2003 07:06 PM
