Advancing intake cam gear too much damage anything?
question is in the title. i seem to remember reading that advancing cam gears too much with toda b's will eat valves. any truth to this?
Advance it too much and valves will touch the pistons= goodbye valves
It's always a good idea, especially with aftermarket cams with more lift, to check piston to valve clearance and how much the cams can safely be advanced/retarded without getting into trouble.
tnx for the response. actualy i put cam gears on my jdm b18cr with stock cams. i set it at +3 (6degrees)on the intake cam, am i still on the safe side?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid ctr »</TD></TR><TR><TD CLASS="quote">Set it back to 0,0 and get on a dyno</TD></TR></TABLE>
Exactly.
How did you decide on the 3° setting? Without a dyno, you have no way of determining what effect the adjustments are having.
Exactly.
i did dyno it. the guy put my cam gears at +4 in, -4 ex. don't really trust the guy who did the adjustments, thats why i'm asking this question. +4 is around 8degrees advanced, im afraid of valve to piston contact with this setting
