CAN ANYONE FIGURE THIS ONE OUT?
Old Dec 1, 2001 | 12:47 PM
Peter Lim 1110's Avatar
Default CAN ANYONE FIGURE THIS ONE OUT?
okay.. my friend's 2000 PY ITR is having some problems. His CEL light keeps going off.. i don't know what code it's throwing.
Here is what I know so far:
1. Car jerks when cruising at constant speed and even under normal/light acceleration.
2. CEL light keeps going off
3. Idle jumps to 1500rpm sometimes
He took it to the dealership and they claimed it was his intake and tried to charge him 72 dollars to check it out. They couldn't figure out what was wrong and tell him the problem is because of his intake (AEM CAI). They took off his intake and cleaned the throttle body. The mechanic test drove it and said it was fine. My friend then drove away from the dealership and the problems were all still there.
Old Dec 1, 2001 | 12:55 PM
WalkmanX's Avatar
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (Peter Lim 1110)
ask for his money back 1st
Old Dec 1, 2001 | 01:02 PM
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (fuzznuts)
Oh he didn't have to pay the money. They "tried" to charge him.
I'm not sure if it's bent valves. He drives that thing like a girl and babies it. His car must have no fun. Kind of sad actually.
Old Dec 1, 2001 | 01:22 PM
oh and where exactly do i find the 2 pin connector to short the service wire. Is that behind the glovebox? anyone got a diagram?
Old Dec 1, 2001 | 01:49 PM
Crossett's Avatar
On the passenger side kick panel, there is a little box with a green plug in it. The box is just there to hold the plug, pull it out and bridge the gap with a paperclip or a piece of wire. Sorry no pic though.
Old Dec 1, 2001 | 08:28 PM
JohnnyBoy's Avatar
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (Crossett)
What is the exact procedure to counting the CEL lights?
Old Dec 1, 2001 | 10:19 PM
Crossett's Avatar
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (JohnnyBoy)
Once you have the plug bridged start the car. The CEL will flash a 2 digit number. The first digit is long flashes, the second short flashes. Then it will repeat, thats the engine code.
Old Dec 1, 2001 | 10:45 PM
ImportReview
Guest
Posts: n/a
Yes...
It looks like a Throttle Positioning Sensor Problem.
The car will jerk sometimes, when your driving it...cause the ECU doesn't know what throttle position your at...possibly the sensor is bad, etc etc etc..
instead of asking questions on the internet, have a mechanic tell you what ECU code it is. Get the code to go on, then leave car running, so they can tell you.
Then its its TPS, fix it, if its different fix that..etc etc. etc.
Good luck pal.
Jeff
Old Dec 2, 2001 | 01:30 AM
Tommy_Gunns's Avatar
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (ImportReview)
Damn, someone beat me to it
I also think it is your TPS (throttle position sensor)...
Yes...
Jeff
Old Dec 7, 2001 | 02:57 PM
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (ok guys i got the code)
Its throwing a code 7.. which is throttle angle i think. So can anyone elaborate on this for me?
Old Dec 7, 2001 | 03:41 PM
STOLEN - ITR 98-0652's Avatar
I'd consider that confirmation of TPS malfunction. It's a quick fix.
Some dealers suck... my Field VTEC controller was generating MAP codes and the dealer (in NC) replaced it (the MAP) twice! No compaints about Field or AEM (or Mugen header / exhaust). In this case, the Field was the cause of the MAP code (although I doubt the sensor was ever bad) - faulty wiring (i.e. crimps and line splices as opposed to soldering).
Old Dec 7, 2001 | 09:16 PM
NighthawkR184's Avatar
After the intake was installed did you disconect the battery cable then reconect it?
Old Dec 8, 2001 | 04:45 PM
Default Re: CAN ANYONE FIGURE THIS ONE OUT? (flamencoR184)
Yes I reset the ECU after installing the intake. I installed the intake on his car almost a year ago. The problems just arose recently.
Old Dec 8, 2001 | 05:51 PM
tatty's Avatar
New User
Link for what to do when your CEL comes on, and how to check the code:
http://www.c-speedracing.com/faq/06.html
Here's the link for ECU codes
http://www.c-speedracing.com/faq/05.html
Old Dec 10, 2001 | 11:39 AM
protocol_droid's Avatar
I had a similar problem in my 95 GSR. At around 2-4.5K rpm, under light throttle, the car would jerk and actually shoot a little forward from it. T'wouldn't happen all of the time, just once in a while, so a mechanic couldn't pinpoint anything. To make a long story short, I had the plug wires checked, they were supposedly alright. I then had a valve adjustment and the symptoms became really bad and it happened in every gear all of the time. The mechanic ended up changing the plug wires and all problems gone.
FAb5
Honda Civic (2006 - 2015)
49
Oct 23, 2009 05:13 PM
JuSsBaLLiN1
Mar 4, 2008 12:07 PM
Harlowe
Honda Civic (2001 - 2005)
15
May 25, 2007 07:53 AM
Infinity_Racer
Honda S2000
10
Dec 31, 2004 05:06 PM
mr devious illusions
Mar 16, 2004 07:49 AM
