Engine Swap Help for a '87 Civic
Old Aug 14, 2004 | 10:39 PM
chupacabrah's Avatar
Default Engine Swap Help for a '87 Civic
I have a carbed '87 civic, but I want to drop in a FI engine of the same type--nothing special just something stock and fuel efficient, and keep it auto (for delivering pizza)
If you could help me out:
what engine/tranny/ecu/etc do i need?
any advice or anything i'd need to know?
My friend has an 88 civic FI 4-door.
I have an 87 civic 4 door, carbed.
basically i want his setup.
thx in advance
Old Aug 14, 2004 | 10:40 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Engine Swap Help for a '87 Civic (chupacabrah)
You can find a D15B2 for cheap, but how difficult to install? I don't know.
Old Aug 15, 2004 | 12:35 AM
rolledthatho's Avatar
"D15B2"
what motor is this? im not to worried with the install as long as its not all custom fab, i wanna buy the motor and trans and ecu and wiring harness and hook it all up
Old Aug 15, 2004 | 12:45 AM
Reign_Racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> "D15B2" </TD></TR></TABLE>
This is the stock block that is in the 88 4-door that you are talking about. If I am not mistaken it will take a majority of custom fab work to put d15 into the 87. I could be wrong but I am sure I read it on the internet somewhere.
Old Aug 15, 2004 | 01:01 AM
Default Re: (Reign_Racer)
"zc swap or 88-89 teg will both bolt right in but there will be some wiring to be done."
i was also told this, but i didnt know if there was an easier way..like i dont know much electronics, what kinda wiring would have to be done
also the more i think about it, if i get any new FI motor, im gonna have to change the gas lines and all that crap fuel pump, **** like that, how hard will this be to
change this all over, to whatever fits in it and is FI automatic and good on gas, what all steps will i have to take to complete this project
i guess to make it easier, say you had an 87 carbed civic and you wanted a new FI motor and auto trans, swap
what would be your check list of things to do/convert down to starting the project until shes ready to fire up again
Old Aug 15, 2004 | 01:40 AM
rjay8604's Avatar
Default Re: (rolledthatho)
changing to FI with a 87 carb'd= killing yourself because of stress. too much work, get a zc and carb that ****. actually heres what you can do go to redpepperracing.com and thats all you'll ever need to know.
Old Aug 15, 2004 | 05:02 AM
Sikocivic's Avatar
Default Re: (rjay8604)
redpepperracing.com
This is the place to go for 84-87 Civics and CRXs
Old Aug 15, 2004 | 05:27 AM
Crakadic's Avatar
You can go with an 86 SI. It is out of the Civic Wagon that year. I did this same swap on the first Civic I ever owned. You get evrything including full harness. The harness will connect right up to you existing pieces and ou will not have to change anything. You need Motor, Tranny, ECU, Harness, Gas tank, Fuel Pump, and you need to run fuel lines. Take a pic of the 86 if you can it will help you out.
Old Aug 15, 2004 | 10:36 AM
Default Re: Engine Swap Help for a '87 Civic (Crakadic)
so the 86 crx si, or civic si, i guess? will bolt right in there? no custom fab? im looking through this red pepper site, its great, also was the 86 FI?
Old Aug 15, 2004 | 01:47 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Engine Swap Help for a '87 Civic (rolledthatho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolledthatho &raquo;</TD></TR><TR><TD CLASS="quote">so the 86 crx si, or civic si, i guess? will bolt right in there? no custom fab? im looking through this red pepper site, its great, also was the 86 FI?</TD></TR></TABLE>
All 85-87 USDM Civic/CRX Si models are MPFI. All the other DX, HF, and STD USDM models from those years are carbed.
And to correct a few things that others have posted...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolledthatho &raquo;</TD></TR><TR><TD CLASS="quote">"zc swap or 88-89 teg will both bolt right in but there will be some wiring to be done."</TD></TR></TABLE>
Be very careful when someone says "zc swap" because there are many different zc engines and most of them fit the 88+ Civics/CRXs. The one that easily bolts into 84-87 Civics/CRXs is the 1g dohc zc, which is similar to the USDM D16A1 engines in 86-89 tegs. The 1g dohc zc is very rare these days and you almost never see them for sale. people will say they have a 1g zc for sale, but it almost always turns out to be a 2g zc or a D16A1 because their head is up their ***. For your 87 Civic the easiest swap is the D16A1 brown top from an 86-87 USDM teg which had 113 hp. Almost as easy (especially because you are doing the carb-to-mpfi conversion) is the D16A1 black top engine from an 88-89 USDM teg which had 118 hp. The biggest difference as far as swapping goes is that the brown top has vacuum advance ignition and the black top has electronic advance ignition. If you are doing the FI conversion anyway you might as well swap in an 88-89 D16A1 and get 118 hp instead of the 91 hp from the 85-87 Civic/CRX Si engines. By far the best way to do the swap is to buy a wrecked or otherwise low priced (body rusted to hell?) 1g teg that still has a good drivetrain because you are going to need LOTS of parts from it. If you buy those parts one at a time from a junkyard they are going to nickle and dime you to death. Go to http://www.redpepperracing.com and read the FAQ thoroughly, then search for "D16A1 swap". AFTER you have done that, if you still have questions ask them over there and you will get many more answers (and better answers) than you will here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crakadic &raquo;</TD></TR><TR><TD CLASS="quote">You can go with an 86 SI. It is out of the Civic Wagon that year.</TD></TR></TABLE>
I have no idea what this means!?! I thought there was never a Civic wagon Si model and that they were all carbed, at least for the 84-87 models that we are talking about.
Good luck.
ahhzel
Nov 23, 2015 06:21 PM
R478n6z44
Apr 24, 2014 04:52 PM
tcav52
Oct 28, 2006 09:35 AM
numbnuts22715
Welding / Fabrication
36
Sep 24, 2004 10:40 AM
