popping noise
OK well my car is making a popping noise when I give it more then like half throttle and when u turn to the left it makes it so I changed the driver side axel and it is still doing it does anyone know what else it could be cause the passenger side Axel is new 2
yea im pretty sure they are all the way in put I will check them 2marrow but they will start popping when I am just goin straight down the rode and give it more than like half throttle
it could be a bad UCA or LCA balljoint. try kicking the tires from the front and back. if you can see hear the popping noise when you do this, then you need to inspect the suspension on that side of the car.
its also possible that the nut holding the tie-rod to the front x-member is loose or that the bolts that hold the x-member to the underside of the car are loose.
