skunk2 intake manifold intalled in eg with h22 swap reveiw
Old Aug 14, 2004 | 07:55 PM
jdmcivicferio's Avatar
Default skunk2 intake manifold intalled in eg with h22 swap reveiw
well I finally got my intake manifold after waiting, what 2 years? anyways my disapointment with skunk2 was once again, investigating the quality of my intake manifold, I find my good friend JB weld inside and out, way to go skunk2, its almost like they didn't want it to fit in civics, because they make the IACV at the back, where it WILL hit the proportioning valve (but the h22 is on the front, go figure), all it looks like to me is a beefed up plenum on the b16/itr manifold, with the h22 flange, but I guess I will truly see what will happen, I think on my setup there should be a jump in power because I was still using the secandaries only the dyno can tell.
heres some pics
Old Aug 14, 2004 | 07:56 PM
Default Re: skunk2 intake manifold intalled in eg with h22 swap reveiw (jdmcivicferio)
oh ya, this was with hasport mounts
Old Aug 14, 2004 | 09:38 PM
Ransom's Avatar
so what were the problems you ran into? im thinking about getting one but i would like to know the problems im going to encounter. on the install though
Old Aug 14, 2004 | 10:15 PM
Default Re: skunk2 intake manifold intalled in eg with h22 swap reveiw (LudeSH)
you gotta lower the proportioning valve, poor design in my opinion
Old Aug 15, 2004 | 06:15 PM
v4lu3s's Avatar
RTFM
well they DID design it for a prelude and even sent along a slip of paper saying it probably wont fit in swapped cars.
i tried mine out in my hatch about a week and a half ago and decided it wasnt worth the effort to get it in since i had a euro-r and str 70mm tb ready to go instead., and it all fit with a lot of room to spare. i may do the skunk2 later once i turbocharge though.
Old Aug 15, 2004 | 08:42 PM
. o 69 o .'s Avatar
Default Re: (v4lu3s)
Skunk2 took two yrs to make this. Very disappointing. Only Dyno will tell... Install is a PITA with Hasport mounts. What about mount kits with HCP where the motor is closer to the firewall?
Old Aug 16, 2004 | 04:22 AM
93H22ACX's Avatar
Default Re: (B16B)
let us know how the dyon goes...good work on the install
Old Aug 16, 2004 | 06:16 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
what about shifting...did you try to see if it kicks back and hits the prop-valve?
Old Aug 16, 2004 | 06:52 AM
. o 69 o .'s Avatar
Default Re: (92hybridAccord)
you have to move the proportioning valve and the lines. If anything, its going to hit the booster and the firewall. Also, if using a Hondata gasket, its even closer and you need to use longer studs
Modified by B16B at 3:48 PM 8/16/2004
Old Aug 16, 2004 | 08:26 AM
the proportioning valve is about 3inchs above the subframe
Old Aug 16, 2004 | 11:18 AM
Newman's Avatar
New User
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 took two yrs to make this. Very disappointing. Only Dyno will tell... Install is a PITA with Hasport mounts. What about mount kits with HCP where the motor is closer to the firewall?</TD></TR></TABLE>
Someone else on here already installed the Skunk2 H22 manifold into their EG Civic with HCP mounts.... fitment and gripes are just about exactly the same. Funny thing is, most people who have gotten the Skunk2 manifolds are disapointed with initial "butt-dyno" results as they feel the car being slower than before, and one guy said he lost power on the dyno but still needed to tune his Hondata. Realisitcally, I see this manifold doing well with either a high compression H22 motor with some good cams, or with a boosted H22 motor. At least with an aftermarket mount kit, the motor will not move and your IACV will (should) not hit the firewall.
Old Aug 16, 2004 | 01:50 PM
cpforyou's Avatar
Default Re: (Newman)
Can anyone give us driving experience as far as hard driving?
Are you guys who have swapped it in having any problems hitting firewall or lines when driving.
Old Aug 17, 2004 | 05:35 AM
Newman...are you guys doing a fitment also on an EG?
also..i recieved the bushings for the mount..thx
Old Aug 17, 2004 | 08:50 AM
hondaZvic's Avatar
hmmm... do we have these same problems with the EK's?
no VTEC on valve cover?!??!?!?! lol blingy though
Old Aug 17, 2004 | 10:21 AM
Default Re: (hondaZvic)
I think it should fit the EK, but the proportioning valve will have to be lowered to fit, I still don't understand why they put the IACV on the back.......
Old Aug 17, 2004 | 10:28 AM
Newman's Avatar
New User
Default Re: (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">I still don't understand why they put the IACV on the back....... </TD></TR></TABLE>
Probably trying to go for that Euro R look, like shown here
If you look at the Skunk2 manifold and the Euro R manifolds side by side, the Euro R manifold is substantially shorter (shorter runners) and it not curved up as much, thus making it look more like a real Integra Type R intake manifold. They copied the same idea with putting the IACV in the back of the manifold also. Too bad the Euro R manifolds don't bolt right onto a reg H22 head
Old Aug 17, 2004 | 11:16 AM
well I guess we will see what power this donkey makes
Old Aug 17, 2004 | 12:14 PM
v4lu3s's Avatar
RTFM
they put the iacv on teh back so they could make a much larger throttle body opening. on teh stock manifold the iacv port goes across the top of the manifold to the front making it hard to overbore to match a 65 or 70mm throttle body.
Old Aug 17, 2004 | 03:15 PM
my stock intake manifold I ported out to 70mm with no problems
Old Aug 17, 2004 | 04:51 PM
Ransom's Avatar
How hard is it to relocate the proportioning valve?
Old Aug 17, 2004 | 09:32 PM
. o 69 o .'s Avatar
Default Re: (LudeSH)
depends how comfortable you are with bending your brake lines
Old Aug 17, 2004 | 10:48 PM
Ransom's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">depends how comfortable you are with bending your brake lines </TD></TR></TABLE>
Thats exactly what i was afraid of...How far does it need to be relocated?
Old Aug 18, 2004 | 03:36 AM
. o 69 o .'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeSH &raquo;</TD></TR><TR><TD CLASS="quote">
Thats exactly what i was afraid of...How far does it need to be relocated?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">the proportioning valve is about 3inchs above the subframe </TD></TR></TABLE>
that gives you a good idea
Old Aug 18, 2004 | 02:07 PM
vtec69's Avatar
Damn thats tight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">
If you look at the Skunk2 manifold and the Euro R manifolds side by side, the Euro R manifold is substantially shorter (shorter runners) and it not curved up as much, thus making it look more like a real Integra Type R intake manifold. They copied the same idea with putting the IACV in the back of the manifold also. Too bad the Euro R manifolds don't bolt right onto a reg H22 head </TD></TR></TABLE>
playlife
May 29, 2015 04:46 PM
weak16teg
Nov 18, 2004 06:53 PM
cccya
Jan 29, 2003 06:48 PM
