Throw Out Bearing?
Old Dec 1, 2001 | 10:59 AM
bahkhok's Avatar
Default Throw Out Bearing?
This morning when I go to start my car I press the clutch in to start it up. When I push down on the pedal at about middle of the pedal travel I hear this ticking sound. It happens either depressing or pressing down. Ist his the throw out bearing? It never made this noise up until this morning. Is just the unnormaily cold weather possible cause of this? What is the worse can happen with a noisy t.o bearing?
Old Dec 1, 2001 | 10:34 PM
rickshank's Avatar
New User
Default Re: Throw Out Bearing? (bahkhok)
If it's just one click each way, it's most likely the throwout bearing binding a bit on the input shaft. Not a huge deal, but if it sticks too much sometime, you'll lose use of your clutch. If you've got over 50k on your car, it might be worth it to have it changed and it wouldn't hurt to do clutch/pressure plate while you're in there.
~Rick Shank
2002 Civic
1989 Civic SI - CSP autocross car
1985 CRX SI - E-Prepared autocross car
civic ef
May 29, 2012 01:02 AM
Unphzd
Feb 21, 2012 07:16 AM
akacoke
Jun 27, 2011 10:48 AM
ether.real
Oct 7, 2009 06:49 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
