Throw Out Bearing?
Old 12-01-2001, 10:59 AM
bahkhok's Avatar
Default Throw Out Bearing?
This morning when I go to start my car I press the clutch in to start it up. When I push down on the pedal at about middle of the pedal travel I hear this ticking sound. It happens either depressing or pressing down. Ist his the throw out bearing? It never made this noise up until this morning. Is just the unnormaily cold weather possible cause of this? What is the worse can happen with a noisy t.o bearing?
Old 12-01-2001, 10:34 PM
New User
rickshank's Avatar
Default Re: Throw Out Bearing? (bahkhok)
If it's just one click each way, it's most likely the throwout bearing binding a bit on the input shaft. Not a huge deal, but if it sticks too much sometime, you'll lose use of your clutch. If you've got over 50k on your car, it might be worth it to have it changed and it wouldn't hurt to do clutch/pressure plate while you're in there.
~Rick Shank
2002 Civic
1989 Civic SI - CSP autocross car
1985 CRX SI - E-Prepared autocross car
civic ef
05-29-2012 01:02 AM
Unphzd
02-21-2012 07:16 AM
akacoke
06-27-2011 10:48 AM
ether.real
10-07-2009 06:49 PM
spens 91 Ef
29
03-08-2009 08:15 AM
Quick Reply: Throw Out Bearing?
