compressor maps
Does anyone have compressor maps for the ITR's, Integra GSR's and SI's (pre-dc5)? I am trying to figure out which turbo would be best suited to my car and want to see how other peoples compressor maps look like for various turbo's.
Dude... umm. Maybe you mean DYNO charts. compressor maps will only have the data for that particular pressure ratio compared to its lbs/min of air flow. THe only way you can make it car specific is if you calculate the particular engine of its air flow capabilities, (using pressure@14.7 stoiciometric, litre size, Volumetric efficiency, and max or midrange RPM) and compare those results to the compressor map for where you want your efficiency to be..
MrBond
Aug 15, 2004 01:15 PM
