Explain this one.....
Old Dec 1, 2001 | 10:47 AM
Blown90hatcH's Avatar
Default Explain this one.....
90 civic Hb. NEw tokicos, ground control, eurathane full bushing kit, eurathane motor mounts.....No boost, low compression...when I dump it a little the thing gets major major wheel hop. But I think that is has something to do with the axles. When it was just a B16a motor...it was fine...then it boosted for a while with the B18c JR....that is when it started. Could it be that my axles are toast? All seals/boots are fine. I can rattle the axles slightly around in the intermediate shaft.
Thanks for your help-J
Old Dec 1, 2001 | 12:02 PM
rioninja's Avatar
Default Re: Explain this one..... (Blown90hatcH)
Shouldnt be able to do that, the intermediate shaft bearing is prolly bad. I'm not sure if its available as a seperate part either, so good luck.
Old Dec 1, 2001 | 11:39 PM
Default Re: Explain this one..... (RioNinja)
thanks...anyone else?
EFDRAG
Mar 13, 2019 01:32 PM
woodenchef
Dec 24, 2012 11:55 AM
tree fingers
Apr 20, 2009 03:16 AM
loudassVTEC
Sep 22, 2005 10:11 AM
honda06si
Aug 6, 2004 07:37 PM
