crx si dohc zc swap codes 1 8 and 9
Old Aug 14, 2004 | 05:41 PM
xjun10rx's Avatar
Default crx si dohc zc swap codes 1 8 and 9
ok like the titlesays i got an 88 crx si with a dohc zc swap, and on the ecu the engine codes 1,8,and 9 keep on coming up.. does anyone know how to fix them.. searched but nothing says how to fix them.. any help would be great thanx in advance...
- junior -
Old Aug 14, 2004 | 06:03 PM
jlicrx's Avatar
Default Re: crx si dohc zc swap codes 1 8 and 9 (xjun10rx)
Code 1 is oxygen sensor - may need a new one
Code 8 is Top Dead Center Sensor in distirbutor - may need new distributor
Code 9 is Cylinder Position Sensor which is on the end of the exhaust camshaft - could be wiring for the sensor or camshaft timing could be off (which could also cause Code 8)
Old Aug 14, 2004 | 06:24 PM
xjun10rx's Avatar
cool thanx, so for the 8 and 9 i might of connected those two wires wrong.. so just try and switch them two..??? and wheres the oxygen sensor??? o2 sensor??
Old Aug 14, 2004 | 07:26 PM
xjun10rx's Avatar
bump... need help guys
Old Aug 14, 2004 | 08:10 PM
xjun10rx's Avatar
help me..... anyone that knows how to fix this...
Old Aug 14, 2004 | 08:28 PM
cbrodac0424's Avatar
Default Re: (xjun10rx)
your o2 sensor is on your header or exaust manifold it is a one wire so that is the one u will need
Old Aug 14, 2004 | 08:52 PM
xjun10rx's Avatar
so code 1 is for my o2 sensor? is this correct?
and how would i fix code 8 and 9
thanx
Old Aug 15, 2004 | 04:19 AM
xjun10rx's Avatar
night bump
Old Aug 15, 2004 | 04:51 AM
Sikocivic's Avatar
If codes 8&9 keep coming back after you reset the ECU then you need a new dizzy. You can use one from a 88-89 Teg. The O2 (code 1) might be OK but because of the other problems you have the motor is not running right and you are throwing the O2 out of its range and the code comes up. I would fix the dizzy problem first and if the O2 still keeps coming up then replace it.
Old Aug 15, 2004 | 04:33 PM
xjun10rx's Avatar
wow good stuff thanx... so switching the two wires to the exhaust cam isnt a good idea or should i try it?... so ur saying just reset and see what happens then go from their...
Old Aug 15, 2004 | 08:11 PM
xjun10rx's Avatar
bump....
Old Aug 15, 2004 | 10:00 PM
xjun10rx's Avatar
night bump...
Old Aug 16, 2004 | 12:20 AM
xjun10rx's Avatar
bump anyone know whats up?? had this problem>>>???
EG6-SIRII
Sep 11, 2006 03:22 PM
BeavisB16
Apr 29, 2005 03:57 PM
hondaspeder
Sep 17, 2003 01:45 PM
Civic Racer X 7
Aug 4, 2003 10:50 AM
