greddy boost controller
profec B spec 2?
You can change the start boost (aka set gain) closer to your desired boost pressure, (desired pressure - 4 psi). That's the pressure where it starts opening the wastegate.
https://honda-tech.com/zerothread?id=931190
You can't make it spool at a lower RPM, but you can hold your wastegate closed a little longer.
jspecegseis
Jun 22, 2007 08:53 AM
