turning on headlights idle drops below 500 rpm need help????
Old Aug 14, 2004 | 03:30 PM
infam0us's Avatar
Default turning on headlights idle drops below 500 rpm need help????
Hey like the topic says. I just dyno and tune my car and with my b20 vtec civic. This has never happen before. I turn on my headlights and the idle drops below 500 rpm. if i turn it off it comes back up to normal idle around 8500-9500 rpm at what it set at. Does anyone know a solution to this??? Is it a alternator problem?? I just broke my alternator belt the other day but replaced it. Need help please.
Old Aug 14, 2004 | 03:57 PM
TIRENECK's Avatar
Default Re: turning on headlights idle drops below 500 rpm need help???? (infam0us)
alternator belt is not tight enough or the battery is bad.
Old Aug 14, 2004 | 04:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infam0us &raquo;</TD></TR><TR><TD CLASS="quote"> if i turn it off it comes back up to normal idle around 8500-9500 rpm </TD></TR></TABLE>
I'd hate to see what your redline is set at. Is your IAC valve working?
Old Aug 14, 2004 | 07:57 PM
speedminded's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infam0us &raquo;</TD></TR><TR><TD CLASS="quote">...if i turn it off it comes back up to normal idle around 8500-9500 rpm at what it set at...</TD></TR></TABLE>...Wow, that must sound interesting idling in a garage or sitting at a redlight... WAHHHHHHHHH!!!!!!! How the heck would you launch?!
ok, back to the real world, it may be the voltage regulator...
Old Aug 15, 2004 | 12:41 AM
infam0us's Avatar
sorry i meant the idle is set at 850 to 900 rpm around there the extra zero was a mistake.
ludedude808
Nov 5, 2006 10:44 PM
PINKS
19
Jul 25, 2006 03:47 PM
Seven18T
10
Feb 16, 2005 04:27 AM
Seedc2
Mar 6, 2004 07:48 PM
96RS
Mar 18, 2003 11:46 AM
