what axels do i need for the b16
I have a 99 b16a2 I am putting into a 91 Si (had a ZC). I am using the hasport kit with hydro conversion. I bought 90-93 Integra axles. What half shaft do I need to get? Also what rear motor/engine mount and driver side block mount do I need?
Also if I run a OBD1 ECU what do I need to change? (ie: distributor, injectors, etc.)
Thanks Much
Thanks Much
On the axle's you need to match the half shaft to the trans. The size of the input is different and wont match the size of the axle seal. If that is not avail you can change the axle seals to match the year of the halfshaft --
So if you are using the 99si hydro trans then get the 99si halfshaft. If all you can find is the older ( 90-93 ) halfshaft then got the dealor and order matching axles seale for both sides of the trans. They should only be a few bucks each.
Hope I explained it ok
if you have 90-93 axles, get a 90-93 int. shaft. Then get the transmission int. shaft seal to match the 90-93 int shaft. Lastly, remove the rings in the knuckle, and the dust seals on the ends of the 90-93 teg axles. Then your set.
Ryan
Ryan
