New with Hondas... Need Help.
Old Aug 14, 2004 | 03:12 PM
.Unknown.'s Avatar
Default New with Hondas... Need Help.
Hey Wassup Guys. I've been around the forums and never posted anything. Well Anyways here's my dilema.
I just bought a 90' CRX Si with the stock motor. (D16A6) Correct? Well i need to change the head gasket. I know most of you would probably say use the search option but i tried and it REALLY didn't solve my questions. I also didn't/don't have time to go pick up on a Helms Book for the CRX. QUESTIONS:
1) Do I have to take off the intake manifold to get to the head gasket?
2) After Removing the Valve cover, In what order, comes off next to get to the head gasket?
3) Do i have to drain anything to get this job done?
LOL sorry for the noob questions i just don't want to do anything wrong. As you can tell I haven't got the experience on working on Internal Stuff. any advice and Help is most Appreciated. Thank you.
Old Aug 14, 2004 | 03:21 PM
mr_valentino20032000's Avatar
Default Re: New with Hondas... Need Help. (.Unknown.)
when i took apart my D16a6 i didn't take off my intake manifold. BUT there is a piece under it that i had a hard time finding (the engine is still in the car) its just a simple plate. You will have to drain your radiator but oil i don't know for sure, i did mine but i'm not sure. And the way i read in my Hanes book is start at the edges and work your way in much like a tire in an X fashion. Hope it helps you out
Old Aug 14, 2004 | 03:32 PM
.Unknown.'s Avatar
Default Re: New with Hondas... Need Help. (mr_valentino20032000)
Kool Thanx for the reply.
Now how many bolts hold down the head? Do i have to remove the Cam?
Old Aug 14, 2004 | 03:43 PM
everything came off in one piece for me. I found this for you....
http://www.binghamtonlife.com/...t.htm
yeah thats everything you need
Old Aug 14, 2004 | 03:54 PM
SlowMotion's Avatar
You do not need to take the intake mani off. I drain my radiator but nothing else. With your motor you do not have to take out the cams to remove the head bolts. I highly suggest you get a maintenance manual(haynes,ect.) before you do this job. It explain the job step by step in detail and pics.
Just off the top of my head you basically take off the valve cover, timing belt, intake mani brace, coolant and elec. connections, and head bolts. Then have fun removing your old gasket off the head and block. I use gasket remover spray and lots of razor blades. This method sucks and takes forever especially with a stock gasket that has been on there for 150k They have rotory tool attatchments that are made to take material off alluminum and work great for headgaskets. I will use this before I do another head gasket. I'm sure I have forgotten stuff so make sure you have a manual before you go yanking your head off.
If you have any other questions just let me know.
Old Aug 14, 2004 | 04:20 PM
.Unknown.'s Avatar
Default Re: New with Hondas... Need Help. (SlowMotion)
Yeah that helped a lot.... I guess i do have to go get one of them books. Anyone know roughly how much they run about?? Good thing i asked you guys 1st before I went to go get started with the "yanking". So far right now I got the Valve Cover off and some hoses connect to the Intake. But that's for the INfo.
Old Aug 14, 2004 | 04:27 PM
SlowMotion's Avatar
You can get Haynes manual at Autozone for around 15 bucks. They say Helm's manuals are better but they are more expensive.
did you check out that site i gave you a link to? Its a web version of the hanes manual. And just check out the head gasket (i think thats it) button. It'll save you $20
Old Aug 14, 2004 | 04:51 PM
.Unknown.'s Avatar
Oh I didn't eve see that dude... Yeah thanx! I'm check it out now.
Old Aug 15, 2004 | 09:00 AM
.Unknown.'s Avatar
ALRIGHT..... I got the belt off... removed my strutbar.... tool the head bolts off, all hoses off disconnected the o2 censor off the exh manifold.... what am I missing? I need help. I'm using the online guide that Mr. Valentino hooked me up with but i can't get the head off... If your Local Holla at the Celle 407.616.6643.
Old Aug 15, 2004 | 11:32 AM
B16 CRX's Avatar
Yha I have change a head gasket on the same motor, make sure when taking off the head bolt there are patterns that you need to fallow, plus you need to torque the head bolts with the right amount of torque, So i would really suggest getting the manual.
Old Aug 15, 2004 | 11:46 AM
.Unknown.'s Avatar
Default Re: (WhiteCRXSi)
Yep I got all the down.... I'm stuck with a hose that connects to the Fuel rail?? I got the had to move around but i believe that's the only thing holding it down. I can't work on it right now cause it's starting to Rain over here in Orlando.
akdrag
11
Oct 5, 2009 07:14 PM
civic_std
Dec 14, 2005 11:27 AM
rasinhell
Jan 24, 2005 09:44 AM
MarkZeroNine
Nov 18, 2003 12:25 AM
dohc-nyne
Apr 22, 2003 03:15 PM
