ZC in crx....what ecu?
http://www.superhonda.com/tech....html
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
PM8 : 88-91 CRX HF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">you know the ecu code?</TD></TR></TABLE>
not off hand, but the 88-89 integ ecu is the one you need. Should be able to pick one up for about 50 or less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">http://www.superhonda.com/tech....html
PM8 : 88-91 CRX HF
There you go pg6
PM8 : 88-91 CRX HF
There you go pg6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vmm »</TD></TR><TR><TD CLASS="quote">its Pg7 integra not pg6...</TD></TR></TABLE>
do you see pg7 on the list above? its pg6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda »</TD></TR><TR><TD CLASS="quote">
do you see pg7 on the list above? its pg6</TD></TR></TABLE>
I've got one laying in my room and it is out of an 89 integra and it says pg7 on the serial number.
people say to use the 88-89 teg ecu but double check the map wires to make sure it is correct. I remember a guy having a issue with the map and ended up the wires don't match up for a 88-89 teg ecu. I have used the zdyne conversion for the hf/si ecu and it works well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">PM7 : 89-91 DOHC ZC (JDM 'EF' ECU) </TD></TR></TABLE>
DOHC ZC = PM7
DOHC ZC = PM7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The ZC »</TD></TR><TR><TD CLASS="quote">Integra ecu is awsome
Worked good for me! even with I/H/E...
</TD></TR></TABLE>Worked good for me! even with I/H/E...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx480 »</TD></TR><TR><TD CLASS="quote">You can use the PM6 ECU (i do, cause I have an Si and it came with the car) but the integra ECU (i dunno PG6 or PG7) has more aggressive ignition and fuel maps so it give you like 10-20 more hp.
So there is a possibility that your ECU (PM5) will work with it. somone please comment.</TD></TR></TABLE>
Yup, PM6 will work, at least to get it running, PG7 will run better and the PM7 will run the best (duh, it came with the ZC).
And his PM5 will not work, its a dpfi ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">I can get you a PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
We here in europe have DOHC d16 stock...</TD></TR></TABLE>
rub it in why dont ya
Wow, such a long thread on something so simple.
A stock Si ecu will work, but lower redline which doesn't capture the whole power band of a dohc zc engine.
The 88-89 integra PG7 is choice due to its plug and play nature, higher redline (7500-7600rpm), and the lack of a speed governor which the JDM version, the pm7 does have.
The true zc pm7 works well to, except it seems like a number of the ones out there when used throw a load detector code. the speed governor kicks in a 112 mph btw.
