Torque Specs on ARP Head Studs?
Old Aug 14, 2004 | 12:27 PM
eRACING's Avatar
Default Torque Specs on ARP Head Studs?
Like the title says... anyone know the torque specs for ARP Head Studs..? I've searched and some say hand tight, some say tq first to 25lb then go 70lbs... some say 80 ft-lbs without the moly lube, etc...
These studs have been used in a previous motor so I do not have the factory moly lube, so if someone could give some advice.. I'd appreciate it..
Old Aug 14, 2004 | 01:25 PM
99B16Si's Avatar
pick up some moly lube and torque them to 25ftlbs then 65-70ftlbs
Old Aug 14, 2004 | 05:45 PM
dfoxengr's Avatar
Default Re: (99B16Si)
follow the directions with the studs you bought.
Old Aug 14, 2004 | 09:53 PM
eRACING's Avatar
Default Re: (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">follow the directions with the studs you bought.</TD></TR></TABLE>
Maybe you forgot to read the second paragraph that I wrote.. Something about "These studs have been used in a previous motor so I do not have the factory moly lube, so if someone could give some advice.. I'd appreciate it.." aka I don't have the instructions anymore.. I'll just do the 25pound torque first then retorque them at 70 pounds..
Old Aug 15, 2004 | 08:19 PM
rbturboda9's Avatar
Default Re: Torque Specs on ARP Head Studs? (erics99si)
if u dont have moly lube use 10w 30 or thicker. first tighten to 25 then 75 i installed arp studs on my integ da other day and thats what da is tructions said if u dont have da lube.
Keenor
Feb 17, 2011 09:18 AM
thedudefromjerz
Jun 18, 2008 05:07 AM
nitroice40
Apr 19, 2008 05:19 PM
slo_b18
Jan 30, 2008 08:47 AM
TokuiAutowerks
Oct 12, 2005 09:11 AM
