Welding on dumtube straight to the wastegate outlet
Old Aug 14, 2004 | 11:45 AM
torr's Avatar
Default Welding on dumtube straight to the wastegate outlet
has anyone ever just welded on their dumptube straight to the wastegate. my bolts backed out when i was night racing and i lost the dumtube. then i guess the heat from the exhaust melted my radiator shroud. so instead of waiting for a new flange i was thinking of just welding a pipe right on the wastegate, has anyone done this?
tial 40mm, steel or aluminum
Old Aug 14, 2004 | 11:48 AM
Doctor CorteZ's Avatar
Default Re: Welding on dumtube straight to the wastegate outlet (torr)
why would you weld it to the WG ? why not just get/make a new flange/dumpipe ?
Old Aug 14, 2004 | 11:53 AM
Chris F's Avatar
Default Re: Welding on dumptube straight to the wastegate outlet (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever just welded on their dumptube straight to the wastegate. my bolts backed out when i was night racing and i lost the dumtube. then i guess the heat from the exhaust melted my radiator shroud. so instead of waiting for a new flange i was thinking of just welding a pipe right on the wastegate, has anyone done this?
tial 40mm, steel or aluminum</TD></TR></TABLE>
Same thing happened to me, while I was at an HPDE. I burned a hole in one of my A/C lines.
I would get a new flange. But I don't see why you couldn't weld one on.
Old Aug 14, 2004 | 11:59 AM
vtec.dc2's Avatar
what happens when/if you need to replace wastegate and you want to reuse dumptube.. i have problem with manifold bolts backing out.. besides using new lockwashers everytime, i double check that its tight on there 50 miles after driving, then couple more times again in the next few hundred miles.. then it stays
Old Aug 14, 2004 | 12:28 PM
torr's Avatar
Default Re: Welding on dumtube straight to the wastegate outlet (vtec.dc2)
well the reason i just don't get a new flange is because then i have to wait for one which we all know takes about 5-10 days. plus the bolts snapped off so there's 2 bolts that are still in the wastegate part of the flange.
oh, well just wondering if anyone's done it. i'll probably end up doing it anyways. do it, do it.
Old Aug 14, 2004 | 01:39 PM
torr's Avatar
i've come to the conclusion, simple idea. i'm gonna fabricate a heat sheild.
T25So
Dec 22, 2005 03:07 PM
patdemps
May 10, 2004 08:48 PM
accordfreak
Aug 29, 2003 03:39 AM
DS1
Oct 16, 2002 06:21 AM
The Punisher
Dec 11, 2001 02:48 PM
