FS: AUDIO EQUIPMENT!!!!! ALPINE!!!! PIONEER!!!! MRD-M500, MRV-T320, SWR-1041D, SPR-176A, DEH-P840MP!
Old Aug 14, 2004 | 09:56 AM
FatJoe's Avatar
Default FS: AUDIO EQUIPMENT!!!!! ALPINE!!!! PIONEER!!!! MRD-M500, MRV-T320, SWR-1041D, SPR-176A, DEH-P840MP!
whats up guys, heres a link to the page i made in the classifieds: https://honda-tech.com/zerothread?id=954101 this one just goes into a lil more detail
Some of you might know an old man wrecked my car and insurance has totaled it so im gonna get rid of it. the new car that im plannin on buyin will have everything i need so all this stuff needs to go. its all basically a couple months old, cept the head unit is a couple years old, still runnin strong tho heres everything i got for sale! (all info is taken from the manufacturers website.)
<U>HEAD UNIT - Pioneer Premier DEH-P840MP</U>
Feeling bored? Need an extreme-audio fix? Open the DEH-P840MP's motorized flap face and spin up one of your WMA- or MP3-encoded discs. Or pop in a regular CD, CD-R, or CD-RW: the DEH-P840MP plays them all, and it also controls Pioneer CD changers. Want a big jolt of color and motion in your dash? The Organic Electroluminescent (OEL) display rocks, with full-motion and 3D graphics and a wide viewing angle. And when the motorized flap face is open, the OEL's dual display areas provide you with two sets of info. MOSFET 50 watts x 4 power keeps things rocking, and if you want to add amps, there are three pair of Hi-Volt (4V) RCA pre-outs at your disposal. The DEH-P840MP is XM Ready and comes with a steering wheel remote. The Premier two-year limited warranty applies.
<U>Alpine MRD-M500 V12 MONO AMPLIFIER</U>
The amazing new V12 AccuClass-D™ mono amplifiers pack an enormous amount of power for your subwoofers. Using sophisticated digital technology, the V12 AccuClass-D™ Mono amplifiers offer unparalleled tuning and control of the subwoofer system. Digital Crossover, Time Correction and Parametric EQ functions are all controlled through the Alpine 'Digital Control Center' located under the top mounted access panel. If you system requires more than one of these awesome amplifiers, simply link them together with the RUX-4280 Remote Amplifier Control Center (RACC) to control all the tuning functions right at the dash!
• 900W MAX Power
• 500W x 1 (2ohm 14.4V)
• V12 AccuClass-D™ Design
• Digital Control Center with LED Display
• Bass Engine® DSP:
- Parametric EQ
- Crossover
- Time Correction
- Subsonic Filter
- Phase Control
- Bass Compensator
• Remote Bass **** or Remote Amplifier Control Center (RACC) ready
• STAR Topology
• 4 Volt Input Capability
• Integrated Wire and Screw Down Terminals
• Variable Turn-on Delay
• Safe Mode
<U>Alpine MRV-T320 V12 2 CHANNEL AMPLIFIER</U>
Road tested and time proven, V12 amplifiers with their "no shut down" design keep playing when you need them the most. The Audio Quality MOSFETS restore power and produce killer, tight crisp bass.
• Max Power (EIAJ) 140Wx2 (4ohm; Stereo) 400Wx1 (Bridged 4ohm
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 50Wx2 2ohm; Stereo (0.3% THD) 80x2 Bridged 4ohm; (0.3% THD) 160x1
•14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 80Wx2 2ohm; Stereo (0.3% THD) 110x2 Bridged 4ohm; (0.3% THD) 220x1
• Bass Engine®
• S/N Ratio 100dBA
• Frequency Response: 10-50kHz
• 12dB HP/LP Crossover
(30-400Hz)
• Speaker Level Input
• Bass EQ Circuit
• Extra Large Gold Plated Terminals with Wire Insert Capability
• Top Panel Power LED
• Continuously Adjustable Crossovers
• DC Straight, STAR Topology
• DC-DC/PWM MOSFET Power Supply
<U>Alpine SWR-1041D 10" Type R subwoofer</U>
The Type-R subwoofers were designed and engineered totally in the U.S. by a specialized team of engineers that know exactly what bass should sound like. These subwoofers have all the high-end components necessary for competition or Bass Engine® systems.
28Hz – 2kHz
• Kevlar Reinforced Pulp Cone
• High Excursion 1” Santoprene® Surround
• Dual Custom Progressive Nomex® Spiders
• Integrated Tinsel Lead Design
• Custom Cast Aluminum Frame
• Extra Length Extended Pole
• Flared Pole Vent
• Bumped Backplate
• Heat Transfer Plate
• High Strength Brass Voice Coil Bobbin
• Double Stacked Magnets
• Heavy Duty 8ga. Push Terminals
• Oversized Parabolic Dustcap
• Magnetically Optimized Motor Structure
• Designed and Engineered in the USA
<U>Alpine SPR-176A 6 1/2" Component Speakers</U>
For those wanting high performance, the Type-R speakers make a perfect choice. These cast frame speakers offer accurate bass reproduction with the parabolic cone design. The midrange and treble has tremendous clarity with our new crossover design and swivel mounted tweeters for maximum imaging in your vehicle. The Aluminum poly-coated cones have strength and quick response that is enhanced by the high excursion magnet design. External 12dB crossovers offer superb tonal balance which make them perfect to play loud and clear!
• 200W Peak Power
• 50W RMS
• Frequency Response: 40Hz – 30kHz
• 1" Soft Dome Tweeter with 15° Swivel Capability (Flush/Surface Mounting)
• External 12dB HP Crossover with Tweeter Protection and Level Adjusment
• Aluminum Coated Poly Cone
• Cast Aluminum Woofer Frame
That is it right there, I also have all the wiring you would need so just ask me if you need that too and we can work something out.
The TYPE R sub is in a .75 sealed box at the moment, let me know if you want it or not.
AT THE MOMENT, i will prolly not be getting rid of this stuff, but within a month or 2, it will def be getting outta my car, so if youre interested let me know.
i didnt post any prices cuz i wanna know what you guys think you should be paying for this stuff. REMEMBER, this stuff is about 2 months old, except for the cd player. everything is in exceptional shape. afterall, it is alpine!
if any of you would like ACTUAL pictures of all this stuff, then maybe ill get off my lazy *** and take pictures of it, so just ask if it matters to you. thanks a lot guys, make my day!
Old Aug 14, 2004 | 11:09 AM
RS Integ's Avatar
Default Re: FS: AUDIO EQUIPMENT!!!!! ALPINE!!!! PIONEER!!!! MRD-M500, MRV-T320, SWR-1041D, SPR-176A, DEH-P84
Where are you located??
Old Aug 14, 2004 | 11:11 AM
FatJoe's Avatar
salem oregon
Old Aug 14, 2004 | 06:31 PM
FatJoe's Avatar
bump
Old Aug 15, 2004 | 11:23 AM
FatJoe's Avatar
Old Sep 4, 2004 | 01:38 PM
antiJDM's Avatar
you have PM
Old Sep 9, 2004 | 05:47 PM
The_Todd's Avatar
Farts in the shower
Default Re: (2thousandcivic)
How much for head...errr the head unit?
Old Sep 9, 2004 | 06:46 PM
DARKSIRACER's Avatar
free bump for cool *** system
slow-ef
Jun 10, 2009 06:05 AM
vr6chris
Mid-Atlantic (Sales)
Aug 20, 2008 10:40 PM
FatJoe
Audio / Security / Video
Aug 14, 2004 09:48 AM
