Installing Pedals
Old Dec 1, 2001 | 07:28 AM
Flux's Avatar
Default Installing Pedals
I'm out installing some new pedals this morning that require drilling. The brake and clutch pedals are covered by a the rubber OEM pedal covers that are simple to remove. The gas pedal has a hard plastic pedal cover and I can't seem to figure out how to get that thing off...
Does the gas pedal cover even come off? And if so, how?
Old Dec 1, 2001 | 07:30 AM
Big Phat R's Avatar
Default Re: Installing Pedals (Flux)
You literally have to tear the sucker off - I used a set of Vice Grips to pry the top back, then the rest slides off the pedal if you pull down.
Old Dec 1, 2001 | 07:34 AM
Flux's Avatar
Default Re: Installing Pedals (Big Phat R)
Got it off... thanks Big Phat R
Old Dec 1, 2001 | 09:09 AM
B2FiNiTY's Avatar
I've heard the gas pedal is a b!tch to remove, how did you get it off Flux?
Old Dec 1, 2001 | 10:05 AM
Flux's Avatar
Default Re: Installing Pedals (B2FiNiTY)
Grabbed some pliers and started prying and bending both the top edges. Eventually the whole thing just slid down after the top was released. It was a bitch, but not to bad once I knew where to attack...
Next problem has been finding good places to drill on those pedals. Not many places that have the clearance behind them for the nut, especially the gas pedal...
[Modified by Flux, 1:05 PM 12/1/2001]
Old Dec 1, 2001 | 11:57 AM
NSX Bob's Avatar
New User
What type of pedals are you installing, out of curiosity?
Old Dec 1, 2001 | 12:00 PM
Flux's Avatar
Default Re: Installing Pedals (Itr00-1374)
They are OMP pedals. Very nice, good design...
Old Dec 1, 2001 | 12:27 PM
1GreyTeg's Avatar
Good choice Flux, I have OMP's on mine. They do the job nicely and help me to Heal-Toe alot easier. Also great for trail braking at the track. Hell, they make controlling the car with the pedals easier altogether.
Good luck,
A.
Old Dec 1, 2001 | 12:32 PM
Flux's Avatar
Default Re: Installing Pedals (1GreyTeg)
Good luck,
A.
Thanks, I finished the install and took it out for a drive and loved how they felt. The heel-toe acrobatics will be much, much easier now...
Old Dec 1, 2001 | 02:42 PM
albert butterbikini's Avatar
New User
hey Flux, where did you get those pedals from? I might have to get a set.
Old Dec 1, 2001 | 02:57 PM
Crossett's Avatar
Default Re: Installing Pedals (typeR158)
Yeah Flux I would like a set of those too, where'd you get'em?
BTW I wanna check your car out sometime.
Old Dec 1, 2001 | 04:56 PM
Dr Pooface's Avatar
Nice! I'm getting those for christmas.
Old Dec 1, 2001 | 06:42 PM
Caffeine Slug's Avatar
Default Re: Installing Pedals (Dr Pooface)
Any pics of them installed? Where did you finally end up drilling the holes (for those of us who want to install the same pedals)?
Old Dec 2, 2001 | 04:53 AM
Cosworth's Avatar
Flux - what material is the surface made out of? it doesn't look rubberized... would it be slippery when wet?
Old Dec 2, 2001 | 05:50 AM
Flux's Avatar
Default Re: Installing Pedals (Cosworth)
The pedals do not have a rubber surface - they are a "raw" aluminum that has some texture on the brake and clutch pedal. It was raining last night while I was out and I had no problems at all with slipping. I'm telling you - I LOVE they way these things feel while driving.
OMP does have these rubber inserts that fit into the pedal holes - but the guy I bought the pedals from said they really don't help anything.
I don't have a digital camera to snap some quick photos, but I'll borrow one and talk some photos that will show the pedals and where I drilled...
Old Dec 3, 2001 | 05:28 AM
BlackAckeR's Avatar
Flux, you answered a post of mine last week when I was asking about Razo pedals... Essentially, you recommended the same ones you just installed, and I'd also like to know where to get those OMP pedals!?
I see you got them off some guy instead of retail; do you know where he might have got them from (web)? I tried the OMP website that was posted in that thread to your response, but I couldn't find any pedals on that site!?!
Old Dec 3, 2001 | 05:35 AM
Flux's Avatar
Default Re: Installing Pedals (BlackAckeR)
I got the pedals from http://www.ompusa.com. They are the 1000 pedals and are on sale right now for $30.
I called to order and spoke with a guy there that was very helpful.
Driving Impressions
85 Franklin Road
5-B Hamilton Business Park
Dover, NJ 07801
800-275-4667
Dr Pooface's Avatar
Check out http://www.ompusa.com/pedals.htm and http://www.ompusa.com/ordering.htm
Old Dec 3, 2001 | 12:19 PM
BlackAckeR's Avatar
Thanks for the ordering info, Dr. Pooface and Flux...
Looking forward to the pics; does the gas pedal cover the entire metal piece you attached it to?
Old Dec 3, 2001 | 02:32 PM
Flux's Avatar
No problem. The gas pedal doesn't quite cover it (you can't really tell). Mine is at a bit of an angle (very slight) to help with heel-toe action. The gas is a bit tricky because there was not a lot of places to drill.
But it all worked out good...
Old Dec 4, 2001 | 05:02 AM
BlackAckeR's Avatar
One last question on this thread; how would it be to screw the OMP pedals into the rubber/plastic pads on the gas/brake/clutch, instead of taking those off, drilling metal, and using bolts? I'm sure the bolts are more secure, but I was thinking if I didn't like them, or wanted to go back to stock, it would be a b*tch to return them to their previous condition...
Has anyone done that? Is there enough rubber material for screws to get a firm grip into?
Old Dec 4, 2001 | 05:23 AM
Flux's Avatar
I don't see how that would really work at all. For one, I dn't think it would really be possible, and two, aI don't think the pedals will be secure that way.
To go back to stock (believe me you never will, pull off the gas pedal cover and you will see it is a 20 cent piece of cheap plastic) you can just unbolt the OMP pedals and slip the OEM covers back on - they will cover the holes.
Pat
Aug 4, 2023 07:08 AM
bonSI
12
Jul 27, 2008 07:35 PM
TheFranchis3
Apr 20, 2004 02:13 PM
Mikes01GSR
Apr 22, 2002 03:33 PM
Dr Pooface
Jan 7, 2002 03:48 PM
