antenna mast ,know how
Manual or power ant.? If manual you just un-screw it with a wrench and screw in another. If tis power, take the lock nut off the outside and un-bolt the motor. Once its removed you will need to take out the ant. mast and tube, ( replace both). Take the small nut off of the ant. cord housing and clean out and broken off meterial out of there and dirt. Re-install mast and tube in motor. and back into car. It shouldn't more then about 1-1.5 hours.
