Dyno results..... I am now addicted
Old Aug 13, 2004 | 09:54 PM
donkiman's Avatar
Default Dyno results..... I am now addicted
Finally finished installing everything and curing all the check engine lights so I took it down to Godspeed in Novi, MI for some dyno and tuning. I'm running stock internals so he said he would tune it conservatively (little more fuel). The a/f was 11.4-11.8 all the way through the band. My plan was to go to 11psi to get upper 200's but 9psi was all it took.
Results: 288.2whp 188.6ft/lb 93 octane 20,000 miles on motor.
I was so pleased with the results. The hp curve is pretty consistent all the way through with no real sporatic jumps or dips. the torque curve on the other hand hits 160 ft/lb at 3300 rpm and then goes up gradually after that. the car is so ******* fast and I am now addicted to turbo. First gear is too crazy its gonna take alot of practice. After 4000rpm the tach just slams to 8000 so fast its almost impossible to shift at the desired rpm. 2nd gear just roars as the turbos already spooled. heres the setup
1997 honda civic dx
1998 b18c1 motor 20,000 miles
t3/to4e turbo
manifold+intercooler that come in max rev kits
hks ssq
tial 38mm
Hondata stage2 w/ chipped p28
rc 550's
Fluidyne radiator w/fAL fan (definetly does its job)
2.5" downpipe 2.5" straight pipe
no cat, resonator, or Apexi N1 muffler (might switch to flowmaster)
ngk8's .024
Brand New OEM Wires
Brand New OEM Distributor and coil
Brand New OEM Cap
couple things i learned....
1. boost IS like crack
2. vtec is irrelevant when boosting (even though i do have it)
3. weight DOES make an enormous difference.
I live in MI and we have the woodward dream cruise every year which goes on for a few weeks. Thousands of muscle cars, compacts, and home made vehicles come to woodward ave to "cruise" up and down. tonight, full of confidence, i smoked a brand new modded s2000 (wasnt even a compitition), a few modded wrx's (piece of cake), a few 04 evos (thought they were fast?), sooo many audis (they weigh 4000 pounds lol). The only car that held its ground was this old camaro ss compeltely worked. The thing just roared from the light all the way through the top of 3rd gear. by the time we shut down we were neck and neck (~85 or 90mph). Anyways I will have a the dyno posted when i get to school so i can use a scanner. lol I finally got my car done today and i leave for school at 4:30am the next day
next summer... upgrade pistons, rods, clutch, and maybe some drag radials for the weekends.
Modified by donkiman at 12:40 AM 6/16/2005
Old Aug 13, 2004 | 09:56 PM
donkiman's Avatar
Default Re: Dyno results..... I am now addicted (donkiman)
All work done by me except for the tuning, of course.
Old Aug 13, 2004 | 09:57 PM
honda9369's Avatar
Old Aug 13, 2004 | 10:35 PM
Rod.'s Avatar
Default Re: Dyno results..... I am now addicted (honda9369)
Teglove2's Avatar
nice job man. My set-up is almost done, just waited on aem ems.....nice kills too
Old Aug 13, 2004 | 10:45 PM
shadow103rd's Avatar
your going to need a new clutch before next summer ....nice numbers.
Pics of car and dyno charts
Jon
Old Aug 13, 2004 | 10:53 PM
MonkeyManStunna's Avatar
Default Re: Dyno results..... I am now addicted (shadow103rd)
dang nice numbers man
Old Aug 13, 2004 | 11:08 PM
MiraiZ's Avatar
Default Re: Dyno results..... I am now addicted (ExcelcivicSi)
nice #'s crackbaby!
Old Aug 13, 2004 | 11:12 PM
forced00si's Avatar
Old Aug 13, 2004 | 11:23 PM
crx2fast's Avatar
Default Re: Dyno results..... I am now addicted (forced00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote"> After 4000rpm the tach just slams to 8000 so fast its almost impossible to shift at the desired rpm.</TD></TR></TABLE>
thats what i like to here
nice numbers man
Old Aug 13, 2004 | 11:33 PM
Tad's Avatar
Tad
power is crazy
if your setup was in an eg hatch with slicks, you could prolly hit mid/low 12's.. meybe..
Old Aug 13, 2004 | 11:49 PM
careawholelot's Avatar
Default Re: (Tad)
boost makes me wet
Old Aug 13, 2004 | 11:55 PM
shermanyang's Avatar
Default Re: (careawholelot)
nice numbers isn't boost great
Old Aug 14, 2004 | 04:23 AM
USDM 4G VTEC's Avatar
I . </TD></TR></TABLE>
#1 is very true
#2 is not as noticeable as before because u actually making some power also before it kicks
i turned VTEC off on my D series and i can tell a diff on top end with and without VTEC..... i drove it a lil bit without it, and when i turned it back on, HOLY **** it does make a difference.... is the fact that we cant hear it anymore, that makes us think is not there
Old Aug 14, 2004 | 03:51 PM
JR Integra's Avatar
Default Re: Dyno results..... I am now addicted (USDM 4G VTEC)
where did you get it tuned?
Old Aug 14, 2004 | 04:19 PM
99B16Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow103rd &raquo;</TD></TR><TR><TD CLASS="quote">your going to need a new clutch before next summer ....nice numbers.
Jon</TD></TR></TABLE>
+1
i give that thing 2 months tops
Old Aug 15, 2004 | 10:51 AM
donkiman's Avatar
Default Re: Dyno results..... I am now addicted (JR Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JR Integra &raquo;</TD></TR><TR><TD CLASS="quote">where did you get it tuned?</TD></TR></TABLE>
It was tuned at Godspeed in Novi, MI. He's been tuning Hondata for 7 years now.
Old Aug 15, 2004 | 11:34 AM
ChaseIntegra's Avatar
The dark side is calling my name louder and louder
Old Aug 15, 2004 | 11:49 AM
MugenPoweredLude's Avatar
nice
Old Aug 15, 2004 | 04:27 PM
Reilly's Avatar
Congrets, nice #'s.
I didn't see what clutch you have, but your going to need one soon if it's stock. That and some DR's and you'll have a blast!
Old Aug 15, 2004 | 04:55 PM
onePOINTsix's Avatar
Default Re: (Reilly)
i hope the dude at godspeed didn't shut the car right off after every run like he did on my friend's 240sx (380whp), they cracked 3 of his manifolds doing that not trying to give godspeed a bad rep but i think that that should be common sense
Old Aug 16, 2004 | 08:06 AM
donkiman's Avatar
Default Re: (Sideout)
I was there while he was dynoing my car and a guy before me's 400whp integra. He did not shut off the car. I dont know who actually dyno's your car but the guy who owns the place has been dynoing for over 7 years. and yes that would be common sense.
Old Aug 16, 2004 | 08:07 AM
donkiman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">i hope the dude at godspeed didn't shut the car right off after every run like he did on my friend's 240sx (380whp), they cracked 3 of his manifolds doing that not trying to give godspeed a bad rep but i think that that should be common sense</TD></TR></TABLE>
Where in MI are you from anyways? I'm from rochester hills area.
Old Aug 16, 2004 | 08:09 AM
donkiman's Avatar
Default Re: Dyno results..... I am now addicted (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">
+1
i give that thing 2 months tops </TD></TR></TABLE>
pics are on the link in my signature. I do not have pics with the front bumper on because I had to leave for college the day after I finished the project. Its a wings west avenger front with silver grill in all the slots besides the stock front grill area, intercooler area and intercooler pipes area. It looks pretty mean.
Old Aug 16, 2004 | 08:50 AM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
i turned VTEC off on my D series and i can tell a diff on top end with and without VTEC..... i drove it a lil bit without it, and when i turned it back on, HOLY **** it does make a difference.... is the fact that we cant hear it anymore, that makes us think is not there</TD></TR></TABLE>
That is totally true. Having VTEC opposed to not having vtec like a B18B vs B18C1 etc is a ginourmous difference.. lol. When VTEC kicks in, you almost lose traction!
