Help 97 accord starting troubleshooting?
Old Aug 13, 2004 | 09:07 PM
tjohnson329's Avatar
Default Help 97 accord starting troubleshooting?
To break it down I have a 97 honda accord 4dr lx, 4 cyl non vtec. I am having a starting problem. I can start the car, and drive to where i need to but then if i get there and shut the car off it won't start back up. It doesn't even crank over the engine all you hear is the starter. I thought it was the battery but when i checked it with my voltmeter with car off it read 12.63 volts. with car on it read 14. volts. so that all seemed ok. I even checked the voltage when the car wouldn't start and it was the same. This problem use to happen when the temp dropped in the summer. I thought that the battery didn't have enough could cranking amps to start the car.I looked at my cables and seen the were corroded along with the terminals. so i deciede to get new cables. has anyone had this problem before and can anyone solve this. the guy at autozone said it was the starter soleniod but i don't think it is. any help would be greatful.
Old Aug 14, 2004 | 12:02 PM
Default Re: Help 97 accord starting troubleshooting? (tjohnson329)
anyone?
bward
Jun 26, 2022 05:30 PM
co5j
Nov 2, 2012 05:30 PM
b72649
Jun 28, 2010 04:16 PM
disturbed_chick
May 26, 2010 01:40 PM
tvnews
Aug 9, 2007 03:54 AM
